blinker relay ????
Old Nov 22, 2007 | 05:03 AM
forrdman_67's Avatar
forrdman_67
blinker relay ????
i have a 2003 f350 7.3 The blinker relay was chattering so i replace
it. Its still doing it now time to time. When it is chattering and i push on the brake peddle it stops but start again after i release the peddle i have checked
for shorts inside and out. I have not fond anything yet. Does anyone here mite know what is cosing this to happen
Old Nov 22, 2007 | 11:36 AM
Clint40's Avatar
Clint40
I changed my relay because I went to led lights and my stock relay wouldnt do the job. You didnt change lighting did you?? Just a thought. Someone will chime in be patient.
Old Nov 22, 2007 | 11:58 AM
santacruzf250's Avatar
santacruzf250
Have you checked your blinker fluid recently?
j/k...
Can you describe when it starts to chatter? and when it goes away. Does it only happen when you use your signals? If so, your signal arm on the column may be going. Also, do you have any bulbs out?
Old Nov 22, 2007 | 12:11 PM
rbaker6336's Avatar
rbaker6336
have you checked tail light sockets for corosion or shorted bulb
Old Nov 24, 2007 | 11:14 PM
forrdman_67
the chatter just comes and goes i have checked everything it is a
flat bed with extra lights on the bed but i have have this truck for 3 years
and it has just started doing the chattering here lately
kodiak_f250
May 20, 2015 04:57 PM
heatherc
Dec 19, 2012 08:59 PM
west tn 6.0 powerstroke
Oct 26, 2009 10:19 PM
JOHNJAY28
Oct 19, 2006 06:23 AM
Blu_Phx
Jan 3, 2006 11:31 AM
