transmission filter pic's
Old Nov 21, 2007 | 11:39 PM
laser1's Avatar
laser1
hi there you helpful lot !
would anyone have a diagram or instructions on changing the auto trans filter ??
thanks in advance
Old Nov 22, 2007 | 03:44 AM
ernesteugene's Avatar
ernesteugene
Make sure you get the correct one. The filter neck length is slightly longer for the 4wd vs the 2wd version. The filter just pulls off, and the new one pushes on the tube. Here's a link to some pics...
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Cod e=E4OD-4R100filter
Old Nov 22, 2007 | 07:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
But the filter o-ring often stays in the bore. You MUST remove it.
Old Nov 22, 2007 | 10:20 AM
4everyoung's Avatar
4everyoung
I found two o-rings in addition to the one on the filter of a friends truck .... need I say he was having transmission problems. Make sure to look up in the hole for more of them.
Old Nov 22, 2007 | 08:21 PM
laser1's Avatar
laser1
thanks guys, as per normal, you are all wonderful !!!
