Help! Parts guys? Multifunction switch
Old Nov 21, 2007 | 07:58 AM
jroehl's Avatar
jroehl
Our church has a '94 E350 cutaway van with the 7.3 IDI diesel. The wipers have had various problems, which we think is due to the multifunction switch. We have removed it and reinstalled it several times, and the problems have changed each time (wipers/washer stay on or intermittents don't work).
Anyway, when I go to rockauto.com they list several different MFSs for this application and I don't know which one to get. The dealer quoted me $130+ for one, but I didn't get any kind of part number from them. Rockauto is about half that for the switch, but it depends on which one I need. I have the switch in front of me, and it has the following numbers/letters printed on it:
(upside down triangle)F3UA13K359CB
4C2436
A
The van doesn't have the auto dimming headlight feature that I'm aware of, and the hi-beams are on the lever (pull forward for flash-to-pass, push back for contiuous hi-beam).
Two harnesses attach to it, the one for the turn signals has 7 pins, the other for the hazards, wipers, washer, etc. has 11 pins with what appears to be either one or two blank spots where a pin could be. Oops, let me clarify, the pins are on the MFS.
Thanks in advance!!
Jason
Old Nov 21, 2007 | 06:18 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
93-96 E350 uses only one switch.
part number F89Z-13K359-AB
Ed
Old Nov 22, 2007 | 02:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Jason
From Ed's post above...F89Z-13K359-AB .. Switch
Ford Suggested List Price: $ 154.89 / Direct Ford Parts FTE Member Discount Price: $82.11
Old Nov 25, 2007 | 12:52 PM
jroehl's Avatar
jroehl
AIRTEX Part # 1S1088
w/Electronic Flasher w/o Auto. Headlight Dimmer
STANDARD MOTOR PRODUCTS Part # DS603 {DIMMER & TURN SIGNAL SWITCH}
With Electronic Flasher; Turn Signal & Wiper Switch
ACDELCO Part # F1525A {#19140276}
SWITCH,T/SIG
Those are three of the options RockAuto.com lists...do you guys have a cross-reference? They are $42, $83 and $85, respectively, without shipping.
Thanks again (sorry I took so long to respond, I was out of town),
Jason
Old Jan 11, 2009 | 12:37 PM
Dale Henson's Avatar
Dale Henson
We have a 97 F53/Motorhome with electrical problems. The turn signals only work on the rear, the 4-way flashers only work on the front, the brakelights don't work at all. You can put a test light to the brake light switch and push the brake peddle and the test light lights up. What do you think the problem may be?
Dale
Old Jun 13, 2009 | 01:57 PM
luckettg's Avatar
luckettg
Dale
I wish someone had answered you as I am having similar problems. No turn signals, emergency flashers, or brake lights, and the gear shift is stuck in park. It is a 1995 F53 chassis used by a 1996 Georgia Boy RV. I wish I had a Ford chassis wiring schematic.
Greg.
Old Jun 14, 2009 | 04:55 AM
txevt's Avatar
txevt
intermit wiper module is under passenger side of dash on the far left. a/c condensation will drip and follow over and into wiper delay module.... causing phantom wipe. mount the delay module up higher. never had to replace a delay module, after it dries out, the delay module still worked.
Old Jun 14, 2009 | 06:44 AM
NumberDummy
Ask, and ye shall receive.
Welcome to FTE
1995 F53 Motorhome Chassis & Electrical Troubleshooting Manual
Item number: FCS1226095 // $22.50
Available from helminc.com / Buy online, or call 800-782-4356.
Helm has printed all of Ford's literature since the 1940's.
In addition to this manual, there are many other manuals available.
Old Jun 14, 2009 | 07:19 AM
subford's Avatar
subford
Greg.
Sounds like fuse #7 or #9 is bad or maybe both in your Instrument Panel (IP) Fuse Panel.
Until you get your diagrams from HELM here is the circuits in question.
IP Fuse Panel:
http://i54.photobucket.com/albums/g9...2FusePanel.jpg
TS-H:
http://i54.photobucket.com/albums/g9...6F53MHTS-H.jpg
SL:
http://i54.photobucket.com/albums/g9...996F53MHSL.jpg
Phanman43
Mar 4, 2014 07:08 PM
1'stonraceday
Electrical Systems/Wiring
Feb 2, 2014 02:23 PM
1'stonraceday
Dec 18, 2013 10:58 AM
waterbear
Aerostar
13
Aug 28, 2010 05:41 PM
