Oil pressure issues??
Old Nov 20, 2007 | 04:35 PM
S_Bruce's Avatar
S_Bruce
Hey guys,
I've got a buddy with a 1997 Expidition 4x4, with a 4.6l engine, auto tranny, at about 110,000 miles. Recently his oil pressure gage has been acting a bit goofy; at random times it will drop to zero, the oil pressure light will come on, and then it will begin reading again. He says that the longest it has stayed at zero is about 5 seconds, and its more prone to happen during acceleration and during uphill travel.
I tend to think it's electrical in nature, as it doesn't seem probable that the oil pump itself would quit running and restart again later (it is mechanically driven, isn't it?)
Where exactly is the sending unit? I followed the lines back from the oil filter, and found two electrical connectors there, and they appeared to be intact, connected, and undamaged.
Any ideas on what could be causing this?
Thanks in advance for the help,
Steve
Old Nov 20, 2007 | 05:55 PM
FTE Herman's Avatar
FTE Herman
Usually, the electricall connector at the sender is making poor contact, but I have to ask, since you state the problem presents itself accelerating and up hill; is the oil at the proper level?
Old Nov 20, 2007 | 06:00 PM
FTE Herman's Avatar
FTE Herman
Old Nov 20, 2007 | 07:56 PM
pitrow's Avatar
pitrow
I was thinking the same thing...
Old Nov 21, 2007 | 06:11 AM
projectSHO89's Avatar
projectSHO89
I'd plan on replacing the sending switch.
The switch screws into the oil filter adapter housing which is different for 2- or 4WD vehicles. All you have to do is identify the housing (the oil filter is screwed onto it - duh!) and follow its length until you find where the switch screws in.
Steve
Old Nov 21, 2007 | 06:42 AM
Modified 99's Avatar
Modified 99
Take out the sending unit and install a temporary pressure gage (0- 100 psi) and get a Real Time oil pressure reading. The electric gage will tell you that there is SOME oil pressure but not how much.
Old Nov 21, 2007 | 01:30 PM
S_Bruce's Avatar
S_Bruce
Thanks for the responses, guys.
Yep, the oil level is in range! That was the first thing I checked, and should have included it in the list of symptoms. Good catch.
So, I guess we can localize this issue to the sending unit itself. I think I found it, followed the lines from the filter back to the block and found two electrical connections. They appear to be making good contact, no frays, no melted insulation. There sure isn't a lot of room to work with in there...
Thanks again for the help, fellas.
Steve
Old Nov 26, 2007 | 10:28 AM
hotstang's Avatar
hotstang
Replace the sending unit
I replaced the sending unit on my 00 gator when it started dropping to 0. Seamed to do it only when the engine was cold and only for a few seconds. Works great now.
