Brake Problems With 01 E350 15 Passenger
Old Nov 20, 2007 | 01:53 PM
Jim_Becker68's Avatar
Jim_Becker68
The ABS light stays lit on my 01 Ford E350 and the van shudders when braking. The brake pedal also pulses with the shuddering.
I took it to a brake place and they quoted a price of just under $900.00....holy smokes!!! They want to replace all the brake pads and all four rotors. I checked Ford's Motorcraft site and those front rotors for a Super Duty E350 are not cheap.....
I haven't been driving the van, except for a short drive here and there, due to the brakes. What I noticed is that rotors surfaces are not completely shinny, but appear to have spots where you can see the surface was contacted by the pad and other areas of the rotor do not appear to be contacted by the pad. To me three of the four rotors appear to have high spots or are partially warped.
Before spending about $600 on four new rotors, plus pads can these rotors be machined? Maybe this brake place doesn't machine and just replaces instead of machining, I do not know.....but I do know that many rotors can be machined to true up the surfaces. I have also heard of single use rotors and drums, which do not have enough material after normal use to be machined.....I am hoping that these are machinable....and saveable.....
Comments please!!!
Jim
Jim Becker
Old Nov 20, 2007 | 06:30 PM
mhg's Avatar
mhg
they should be machinable
find another brake shop
there is a possability that once machined
you will still need to replace a rotor
there may be one or more warped bad enough
that once cleaned up they may be too thin
but only after they have been machined will you know for shure
probably only one is warped really bad and causing the vibration
Old Nov 23, 2007 | 01:17 PM
Desert-Rat's Avatar
Desert-Rat
brakes on an e-350 are a bit tougher than most trucks. I heard that you have to repack the front hub when removing the front rotors... I have not had to do my brakes yet. I am still at 50% front and rear at 48k miles. keeping my fingers crossed. I would try and have the rotors machined first. there is no way the brake shop could have told you that the rotors were unsaveable without taking them off. sounds like they dont want the hassle of resurfacing... I would find another place.
corksil
Jun 30, 2015 09:25 AM
BaitGuru
Jan 20, 2015 06:53 PM
jbh114
2009 - 2014 F150
25
Apr 27, 2014 07:38 PM
zippinz
Aftermarket Products
Aug 5, 2002 08:56 AM
jim henderson
Mar 27, 2001 06:40 PM
