# 3 MISSING
# 1 @ https://www.ford-trucks.com/dcforum/DCForumID9/1335.html
# 2 @ https://www.ford-trucks.com/dcforum/DCForumID9/1347.html
# 3 @ https://www.ford-trucks.com/dcforum/DCForumID76/10.html
well i have made progress in that it is a miss , or dead miss , not rought idle.... as of this morning.. i swapped around several injectors to make sure it was or was not an injector & it was not.. also re-set timing from beginning , and replaced plugs , cap . rotor , wires .. all with top line from my NAPA store,,, anyway started to check into valve issue ,, since # 3 plug still foul out with fluid ( gas , i believe not oil) ,, I removed valve cover , re-installed intake , ect .. started motor , watched oil start to splash around ( keep outside of block from rusting ) , and lossened the intake & exshaust # 3 , wow , it idle smooth , / or shall i say it no longer missed !! and now when the # 3 injector wire harness is unplugged the rpm drop's & run's like crap , as happens when you do the other injectors wires , so problem is an valve issue,, even on new motor it is possible,, well with the rocker arm bolts loose enought to make it run right , there is also the situation of being able to turn the pushrod's around by hand with motor running , ( ONLY on # 3 thro- ) , and the bolt's now seem to start to back them selves out as it run's , i am sure they would continue till they fall out.. so if i have to have the rocker arm bolt's that loose , along with puch rod issue , possibly colasped lifter's , or at least not pumped up like rest ????? hate to pull that side cover & change 2 lifter's ,, any other idea's ??? please post here & also e-mail me @ coorslight4u@attbi.com thank you...........mark
anyone want to help with this on land line , let me know . i will greatly pay long distance charges........ I am in salem oregon.. come on FORD BROTHERS , help one out... some one here must know about valves & lifters more then me ...
and it all started , ,,, they were out of the part as , well, before i left thou- the sales person, said "hold on", he went to the back & came with a pump
, i asked thought you were out , he said " the 4.9 is same as in a 92 250 ,,, anyway , he said this one will work, .. i asked even though part # different ??? he said yes .. :-X11 so took it , put it on & started truck,,
WOW the noise was bad ,, & the water & steam out tailpipe ... well the one i needed had about 1 1/8" thick housing , & the one he sold me had about an 5/8" houseing & top water pump mount bolt , went right thru cyl. wall & when piston came up is groved right down thru rings... now water in head ...
so i took some time off & got them to replace the motor , not sure what brand it is, but was a compltete long block,, & got $$$ from them for having it put in, spent week-end doing that,, anyway.. problem with it is warranty issue's are handled thru there corp office in memphis... and a real pain to get things handled ,,, let me end this rampage by saying .....NAPA HAS NEVER FAILED ME !!!auto zone is the rip off store, go in rich & leave poor...
