need help
Old Nov 19, 2007 | 10:22 PM
Lunch Meat's Avatar
Lunch Meat
need help
I noticed when I take off a very slight jerk, you have to feel for it to notice it.
I am wondering if is a transmission problem, or is it further back
Old Nov 20, 2007 | 04:28 AM
npccpartsman's Avatar
npccpartsman
We really need a little more info. on your truck--2wd/4wd, manual/auto, year model, engine, cab configuration.
Just to hazard an initial guess, I'd say you were experiencing Ford's crappy spline lube (or lack of) on the driveshaft joint. You can find fix instructions here: http://www.eurekaboy.com/f250/slipjoint.htm
The tech folders at the beginning of this forum and the superduty/heavyduty forums provide great information about these trucks and the fixes for some of the "common" problems associated with them.
Old Nov 20, 2007 | 06:20 AM
Lunch Meat's Avatar
Lunch Meat
My truck is a 2003 f250 6.0 crew cab 4x4, with an automatic transmission. it doesnt feel like a slip. It feels more like there is slack in something.
Old Nov 20, 2007 | 07:26 AM
npccpartsman
Exactly. Follow the instructions in the link I provided and you'll see that you'll loose a lot of the bump/clunk/jerk you are feeling. It's very very common with these trucks, especially the ones with the long driveshaft like you (and me) have. It takes less than an hour to do. If you still have problems then come back and we'll look elsewhere, but I think that's a lot of what you're feeling. You should also inspect the u-joints while you're there, but I suspect lubing the driveshaft will help tremendously. How many miles on your truck?
Old Nov 20, 2007 | 08:18 AM
Lunch Meat's Avatar
Lunch Meat
86000 I appreciate the info, I am going to do that this weekend
Old Nov 20, 2007 | 08:19 AM
Lunch Meat's Avatar
Lunch Meat
Also will this put ware on the transmission
Old Nov 20, 2007 | 08:24 AM
phish555's Avatar
phish555
npccpartsmanThanks for that link. My truck does the same thing. 06 with 98K on it. I only notice it once in a while. Like if im stopped at a light, and let off the brakes to inch forward then apply the brakes again. Its like a slack in the drive line.
I will try that fix today.
Old Nov 20, 2007 | 08:28 AM
denman81's Avatar
denman81
hey partsman, that yolk that supports the splice between the two shafts has a rubber boot in it, I can grabb my shaft and wiggle it up and down in that boot like its worn out. Is it suppose to do that? Been meaning to talk to ford about that, but if someone can save me the trip, Great!
thanks!
Chris
Old Nov 20, 2007 | 09:25 AM
npccpartsman
I don't know Chris. That might be something to ask the guys in the Superduty/Heavyduty forum. I'm sure it's come up before. I'd kinda like to know that myself.
Nice post about the backpressure issue BTW.
Old Nov 20, 2007 | 11:53 AM
denman81's Avatar
denman81
Thanks! Never said I know everything about these trucks, Im still learning something new everyday, Just trying to keep an open mind while learning! (And a little teaching from a very smart certain programmer helps too!)
Old Nov 20, 2007 | 01:14 PM
phish555's Avatar
phish555
OK, went to grease my slip joint and found that it doesn't look like in the pics at the how to site. My 06 has another u-joint behind the carrier bearing, then the slip joint with the boot covering it. Could this still be the cause of the slack I feel at times in my drive line?
Old Nov 20, 2007 | 03:35 PM
npccpartsman
That's the one that needs the grease.
Old Nov 20, 2007 | 09:34 PM
Lunch Meat's Avatar
Lunch Meat
thanks for all the info
