I had a buddy put a set of those on his 79 f-250 4x4 that was a ground up resto and he had to cut almost half of the inner fender off and did a lot of fab work to make it look good.(show truck)
how hard will it be to install them with the fenders on
Are you talking about the inner fenders? IF so, you couldn't install them until you did some cutting, but once you do some fitting and tracing you could cut out what's needed and put them on.
Other than that I haven't actually installed fender well exit headers, so I'm not sure if it'd be easier or not.
I'm sure it can be done either way, but I don't know anyone that pulled the fenders spesifically to install headers.
Good luck.
