64 ford ideas
Old Nov 27, 2007 | 01:53 AM
frty7ford's Avatar
frty7ford
it is hard to tell could be an oil pressure problem and the lifters were not pumped up. A collapsed lifter would act like a bent pushrod.
Old Nov 27, 2007 | 02:09 AM
tx64f100tx's Avatar
tx64f100tx
so should i hook up an oil pressure guage and see if i tend to have inconsistant pressure? or is there another way i should check?
Old Nov 27, 2007 | 08:38 AM
garbz2's Avatar
garbz2
You damaged the engine when you had the timing 180 degrees off and ran it, There are no short methods of fixing mechanical damage.
The Y block is a mechanical mushroom solid type lifter. No hydraulics involved. Straight metal on metal with a little oil thrown in for lube. Its why things really break in a Y block when the gear mistake is made. The Y's lifters have to be removed with the engine upside down or with special fabricated clips to allow the cam to slide out.
Face it. its toast and needs internal attention.
Garbz
Old Jan 1, 2008 | 04:10 PM
TNT1968's Avatar
TNT1968
I'm not sure why a blown head gasket isn't suspected here. A warped head and/or blown head gasket would/could take out a whole bank of cylinders. I would look for bubbles or worse (oil) in the radiator fluid while the truck is running.
Old Jan 1, 2008 | 09:52 PM
rogue40's Avatar
rogue40
Plugged lifter oil journal.
Old Jan 2, 2008 | 09:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by tx64f100tx
i got out there and get in and it seems as it is idling high so i try to kick it down by stepping on the pedal.. well it just wouldnt go down so i wasnt sure what was going on.
Kicking down on the gas pedal doesn't work when trying to bring the idle RPM's down....
....When you have a manual choke.
Clickity-clack...clickity-clack = Y blocks have solid lifters.
