what type fluid?
Old Nov 19, 2007 | 07:21 PM
frankenbroncoII's Avatar
frankenbroncoII
what type fluid?
i have an 86 ranger 2.3L with the toyo-kogyo 5 speed. being thats its used and over 20 years old the owners manual is long gone. what type fluid goes in the tranny? is it 80w or atf?
Old Nov 19, 2007 | 08:35 PM
Benaghetto's Avatar
Benaghetto
Atf goes into my 94's M5OD, but I doubt that this helps you out at all. I dont believe that high weights of oil have been used in trannys for quite some time now. Anyone else with a TK5 in their truck want to chime in??
Old Nov 19, 2007 | 08:45 PM
bazzman1953's Avatar
bazzman1953
https://www.ford-trucks.com/forums/6...eeds-help.html
and this
https://www.ford-trucks.com/article/...e_Measure.html
Suprised me that it was Mercon ATF.
Ben, I'm going to drain, and refill this time with mercon [it's low and I don't like the color that is weeping out AT ALL, looks original], but come summer I'm going fully synthetic, when I do the PM.
Far slicker.
Old Nov 19, 2007 | 11:17 PM
Benaghetto's Avatar
Benaghetto
I understand what you are saying bazzman, but he has a different tranny all together. I was just pointing out that my tranny takes ATF, and his probably does to. However I'm unsure about anything to do with his tranny being the TK5.
Old Nov 20, 2007 | 08:33 AM
BSmitty's Avatar
BSmitty
The TK5 takes 80W90. The only trans that calls for ATF is the Mazda M5OD R1.
edit:
Bazzman, what year truck do you have? Are you sure you have an M5OD? The TK4/5 and FM145/146 all take 80w90.
Old Nov 22, 2007 | 12:52 AM
epion04's Avatar
epion04
mine may be in the wrong year but my 91's mazda 5od takes 90 weight
Old Nov 22, 2007 | 01:52 AM
R031Kona's Avatar
R031Kona
The Mitsubishi takes 80W90, I am pretty sure the Toyo-Kogyo takes 80W90 as well , the M5OD (Mazda) all take Mercon not gear oil. Make sure you check the level in the overdrive as well.
Old Nov 22, 2007 | 08:34 AM
99F150's Avatar
99F150
better make sure what is needed. Go to ford.com and register under owners and download owners manual.
it would be better to put atf in a trans calling for oil than to put oil in a trans calling for atf.
my 1988 mazda trans called for atf.
Old Nov 22, 2007 | 05:24 PM
frankenbroncoII
after some some extensive research, it calls for mercon fluid. thanks to all. and happy turkey day.
Old Nov 22, 2007 | 05:45 PM
bazzman1953
edit:
Yes, my '94 is an M5OD, and indeed it took Mercon.
When I drained it the fluid looked anything but red except up on the side of the drain pan. Not a pretty sight, but thankfully there were no metal shavings on the magnetic drain plug, just sludge. Refilling it was a two man job [or in my case me and my owner {wife}]. It quieted the tranny down somewhat. Reinstalling the shiftboots 50mi. down the road worked wonders. No way could I handle that racket for another 400+ mi.
Old Nov 22, 2007 | 06:06 PM
frankenbroncoII
here is the thing that puzzles me, and this information is from the chilton manual. the 4 speed takes sae 80, the fm 145/146 both take the 80w. but the tk5 and the m50d take mercon... what is the difference between the tk4 and tk5 other than O/D, that would make one take 80w and the other take mercon?
Old Nov 22, 2007 | 08:57 PM
99F150's Avatar
99F150
not sure of difference but some transmissions switched from gear oil to atf due to bearing failure from to thick of oil.
I have been using royal purple syncromesh in my Ranger 5 speeds and my F150, sems to hold up much better than mercon and is correct viscosity plus has additives for the syncros that mercon doesn't .
Old Nov 23, 2007 | 03:48 AM
87 XLT's Avatar
87 XLT
Yep, synthetic is the way to go. I've been running 80W90 Amsoil in my 87 2.9 with TK 5 speed for 237,000 miles and the trans is still going strong.
Mikerage
1997 - 2003 F150
Oct 6, 2017 07:02 AM
panteramatt
Oct 20, 2016 07:18 AM
66with352
1997 - 2003 F150
Sep 6, 2016 09:32 PM
daveplot
Jun 27, 2011 12:05 PM
tag187
Jul 19, 2008 09:02 PM
