traction bars
Old Nov 19, 2007 | 06:27 PM
vindex1963's Avatar
vindex1963
Trailering
traction bars
I can't find traction bars for my truck, all the listings stop after 2002.
The rear end on mine is mounted on the bottom of the leaf springs so
the traction bars need to clear the rear end.
I have a 2007 XL 3.0 5 speed stick with 31s and Rancho shocks.
My problem is off road climbing the long dirt roads here in Arizona. Some are very steep and my back wheels start wheel hopping. I have limited slip and a stock suspension. The truck climbs just fine until I hit any high spots the the hopping starts.
Will these clear the rear end?
http://store.summitracing.com/partde...5&autoview=sku
Summit won't give me a straight answer they just say "buy the universal ones".
Old Nov 19, 2007 | 06:42 PM
Benaghetto's Avatar
Benaghetto
Notes: Designed for vehicles that have leaf springs mounted below the axle tube.
Our Rangers have the leafs mounted on the top of our axles. Other than that technicality if you can find a universal set that works for above axle leafs you more than likely could make it work. They are "Universal" after all. You can always sell them to me to put on my Chevelle if they dont work out!
Check these out for full size truck.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=LAK%2D21715&N=700 +4294881589+115&autoview=sku
These actually mention the Ranger and other small sized trucks as applications.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=LAK%2D21905&N=700 +4294881589+115&autoview=sku
Give those a look and let us hear back about what you figure of it.
Old Nov 19, 2007 | 06:46 PM
rubydist's Avatar
rubydist
James Duff makes some bars that have gotten very good reviews:
http://www.jamesduff.com/broncoII/tracbar.html
Old Nov 19, 2007 | 07:29 PM
vindex1963's Avatar
vindex1963
Trailering
And there is the problem, they are for Rangers but stop at 2002, mine is a 2007. Lakewood also said universal but didn't give a part number or why they stop at 2002.
VERY frustrating.
Old Nov 19, 2007 | 07:38 PM
vindex1963's Avatar
vindex1963
Trailering
Originally Posted by [left
rubydist[/left]]James Duff makes some bars that have gotten very good reviews:
I sent them en email to see if they fit. These would be perfect for ground clearance. NICE thank you.....
Old Nov 20, 2007 | 09:21 AM
wendell borror's Avatar
wendell borror
The traction bars stop axle wrap on hard excelleration, but won't stop that wheel hop you get on hard pact. I experienced the same thing when I would wheel in W,Va, I would be climbing on a hard pact trail and would get the wheel hop, mainly going up hill. That comes from having a stiff suspension and thats what you want on a 4x4 for off/road. After a while you just get use to it, one thing that does help is to air down your tires a little. I done this for better traction in the rocks and noticed it stopped a lot of the wheel hop. Mainly, you just sorta get use to it, I've heard some say that a good quality lift kit can help in this area, I only had my t-bars cranked, so I really don't know.
Old Nov 21, 2007 | 09:19 PM
vindex1963's Avatar
vindex1963
Trailering
wendell[/left]
borror
]I done this for better traction in the rocks and noticed it stopped a lot of the wheel hop.
Most trails in Arizona are like a gravel driveway.
My truck is a 2WD so all the traction I can get will help.
The James Duff bars are on the way.
Old Nov 21, 2007 | 09:54 PM
07F1504x4's Avatar
07F1504x4
go to www.stuffforyouranger.com and the left hand side click on driveline and then scroll down you'll see traction bars
Old Nov 30, 2007 | 09:56 PM
vindex1963's Avatar
vindex1963
Trailering
James Duff traction bars installed tonight. It's raining in Phoenix so I had the chance to test them and NO WHEEL HOP!!!!! I need the off road test also but it seems like a winner. The rear suspension is stiffer for sure.
Wreckit87
2009 - 2014 F150
18
Sep 16, 2015 07:48 PM
Sous
22
May 11, 2015 09:35 AM
skoveng
Jul 4, 2013 01:16 PM
Cdan
Apr 18, 2013 09:56 PM
t_hess66
Jun 3, 2011 03:33 PM
