9"vent
Old Nov 19, 2007 | 09:21 AM
beartracks's Avatar
beartracks
9"vent
Anyone know where I can find the vent nipple for a 9'' differencial? It's a standard thread, not pipe. Also passes through the brake line "Y" block.
Old Nov 19, 2007 | 03:53 PM
beartracks's Avatar
beartracks
Found it. At the dealer. Had to get it in from Taos and buy twol.
Old Nov 20, 2007 | 07:10 AM
rusty7983's Avatar
rusty7983
why did you need a new one? i usually soak them in degreaser and clean them out. they plug up but i've never seen one go bad.
Old Nov 20, 2007 | 09:23 AM
beartracks's Avatar
beartracks
When it came out it didn't have any threads on it. I'll have to carefully retap the hole and hope it grabs. Other wise I would have to pull an axle to drill, tap and bush the hole without getting shavings in the housing.
Old Nov 22, 2007 | 07:31 PM
rusty7983's Avatar
rusty7983
is it broken off? do you see parts sheared off inside? maybe easy out it out?
smallello
68
Jan 7, 2023 07:11 AM
jw-wa
Feb 22, 2015 12:16 PM
lafermedavid
Sep 4, 2014 11:08 PM
karolmommy
May 20, 2014 06:51 AM
kioolt
May 10, 2001 04:29 PM
