What exactly do you mean by big block Lightning? The first generation Lightning comes with a 351w small block. If this is your engine then try summit racing, they have lots of options.
528 ci , 460 based that is how it comes out liters.
So what you are saying is that you have a 460 stroked to 528 cid in a Lightning and you are looking for a set of commercially available long tube headers??
I'm afraid you are not going to easily find pre-built headers with bigger than 1-7/8" primaries, and with a stroker engine, I'd imagine you're after 2" or greater. You're probably going to have to weld up your own.
I bet that thing will pass everything except the BP station. GEEZ. How the heck you keep rear tires on that thing? Or do you worry about the tires? That's a whole lotta motor.
It's actually fairly common thing to do.. bore and stroke a big block ford. Just like people bore and stroke most other things they can find.
No kidding.
Most folks who stretch a 385 series to an inch of its life are not going to have to ask about building up a set of headers. I'd like to hear his story, thats all.
