Tach Addition
Old Nov 18, 2007 | 09:22 PM
sheridba's Avatar
sheridba
Tach Addition
Hey everyone...Have a 93 f150 XLT 5.0 (actually 331 stroker), no factory tach, but I had a friend generously donate a BMW heads-up tach. Will be a great addition, reflects on the windshield and looks great. Can get her going with the pos/neg hookup, but wondered how to tap into the rpm readings. Problem is, the directions are all in GERMAN! Didn't know if I tap into the juice for the MSD blaster coil or if the distributor has a tab I need to run off. It is a 4wire system, can't translate what the 4th wire goes to though. I have a pos, neg, rpm signal wire, and another wire. Any thoughts or suggestions as to getting it to read and work or is it not possible to add a digital tach on the truck without some serious mods? Let me know if anyone has ideas. THANKS!
Old Nov 18, 2007 | 09:53 PM
Dean88's Avatar
Dean88
The tach that I helped one of my friend put in his truck had 4 wires. 1 hot, 1 ground, 1 signal wire, and 1 that tied into the lights, so when it was dark and you turned on the lighs, the face lit up.
Don't know about your crazy german one tho.
Old Nov 18, 2007 | 09:58 PM
Wild Karrde's Avatar
Wild Karrde
I would imagine that on a HUD it would be a "dimmer". It would make the tach less bright when you turn on your headlights, so at night you aren't completely blocking your view with it.
Those things have to be pretty bright during the day to see, but at night it would be overpowering.
I can't say for 100% certain, but that's my guess.
Old Nov 18, 2007 | 09:59 PM
Dean88's Avatar
Dean88
I going to agree with Wild Karrde's guess, its what makes sense to me.
crestfallinman
Sep 28, 2011 09:01 PM
army89
May 16, 2011 08:23 PM
bigteal
Mar 13, 2009 02:14 PM
markjw
Electrical Systems/Wiring
Jun 15, 2006 09:44 AM
ROKRAWL
1966 - 1977 Early Broncos
May 12, 2003 09:09 PM
