Clip Source
Old Nov 12, 2007 | 09:53 AM
jowilker's Avatar
jowilker
Clip Source
Anyone know of a replacement source for the clip that holds the heater control **** on the shaft. Mine has the hind legs broken off and the **** will not stay on. The clip will stay on the shaft while the **** is in my fingers.
Don't know why, but it isn't the issue in the summer time.
John
Old Nov 12, 2007 | 11:40 AM
Redmanbob's Avatar
Redmanbob
isnt it just a standard C clip ?
Old Nov 12, 2007 | 08:42 PM
merc390's Avatar
merc390
If the clip stay's on isn't the back off the **** broken??Mine all have the clip in the back off the **** and can be released with a small pick.If the clip stays on then the back of the **** is damaged.
Old Nov 13, 2007 | 05:41 AM
jowilker's Avatar
jowilker
merc, Mine is all buggered up inside and the clip locking feet are broken off. Before I got it freed up it was very hard to turn.
I may have to use a different **** altogether.
Since this is the first church of the ol Ford truck, I came here to pray. lol
There are answers in this place. Folks help one another.
John
Old Nov 17, 2007 | 02:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jowilker
Anyone know of a replacement source for the clip that holds the heater control **** on the shaft. Mine has the hind legs broken off and the **** will not stay on. The clip will stay on the shaft while the **** is in my fingers.Don't know why, but it isn't the issue in the summer time.
John
You can steal the clip off the wiper **** since the ***** are identical.
The clip only came with the ****, t'wasn't available separately.
C1TF-17513-A .. ****-Heater/Wiper Switch 1961/69 ALL trucks.
Old Nov 17, 2007 | 03:52 AM
jowilker's Avatar
jowilker
Big thanks Bill, I will be going home on T-day and have some spares up there. I will be more careful taking it apart. I think yanking on it is what happened to the clip on there now. Someone had mentioned a set screw but this one doesn't have one. Do you know which year models did?
When you need something, just ask here, there are answers to be had.
John
Old Nov 17, 2007 | 04:04 AM
NumberDummy
John
Set screws = Up to 1960, then 1970 and later on some *****, others continued to use the clip. Many of the later ***** were the same ones the cars used. A paper clip can be used to trip the clip, so the **** can be removed. I had a friend once that was trying to move that clip. He was laying cattywampus on the seat with his feet up against the back glass, cussin' a blue streak. I said "why don't you just turn the **** so the clip will be easier to reach?" The look on his face was priceless, and he said "why didn't I think of that?"
On some of the 1960 and earlier trucks, the heater **** was part of the cable assembly and can't be removed.
Old Nov 17, 2007 | 11:21 PM
camperspecial65's Avatar
camperspecial65
Bill...the 17513A NOS **** I got is of the setscrew type....
cs65
Old Nov 18, 2007 | 07:57 AM
FordBoypete's Avatar
FordBoypete
Wink
John
86-96 use similar clips in both Triangluar & One Sided/flat-round type config's, on the various ***** of F-150 XLT style dash panels.
IOW, all shafts coming thru' the trim panel use a step/tension clip retainer set up. I believe they are still available at Henry's Parts Dept, although they are not listed as for 60's or70's models by FoMoCo's parts Literature.
You need to have a "friend" [read as connection] in a FoMoCo Parts Dept willing to take the time to help and/or work with you thru "trial & error" searching. or go to a salvage yard & start releasing & checking out the *****.
FBp
Old Nov 18, 2007 | 05:18 PM
jowilker's Avatar
jowilker
Pete one of them fellows is going to hard to come by, so darn many of them are concerned about how many non gray hair they still have on the rock, they can't read past the current parts book page. lmao
John
