confused
Old Nov 18, 2007 | 06:23 AM
bigben4x's Avatar
bigben4x
confused
I just replaced the pass side hubon a 04 explorer 4.6 4x4. Now the 4x4 high light and abs light is on. It also engages in 4x4 when turning. The abs wire doesnt connest all the way in the harneess on the fender its in as far as it will go. any help much appriciated. There is no trouble codes witha autoxray scan tool.
Old Nov 18, 2007 | 06:31 AM
99f350sd's Avatar
99f350sd
You have to have a bad connection Or routing problem.
Dick
Old Nov 18, 2007 | 08:04 AM
steve(ill)'s Avatar
steve(ill)
take the connector apart and look. one of the two pins can get bent and not engage, then you cant slide it in all the way. ABS lite comes on after starting moter, prior to you moving the truck?? that is the ABS check to see that wires are connected.
Old Nov 18, 2007 | 12:57 PM
bigben4x's Avatar
bigben4x
Im going to try a new connector because its not connecting all the way
Old Nov 18, 2007 | 01:05 PM
99f350sd's Avatar
99f350sd
Maybe there's an old rubber gasket in there from the other bearing..Should only have one.
Dick
BIGBAND39
Escape & Escape Hybrid
39
Mar 24, 2016 12:23 PM
Taylortd
Oct 13, 2015 09:35 PM
Branny08
Apr 2, 2012 07:02 PM
maxxf150
1997 - 2003 F150
Aug 5, 2009 03:04 PM
alf
1997 - 2003 F150
Feb 6, 2002 11:07 AM
