Engine Service Light
Old Nov 17, 2007 | 04:28 PM
ANDEN's Avatar
ANDEN
Question Engine Service Light
1989 Ford F150, 302 5.0L, AOD
I'm not sure were to start with this one.
My engine service light is coming on once the truck is warmed up and I give it some gas.
I pulled the code KOEO code 67.
Tried also with the engine running and found nothing.
The code 67 seems to be for the neutral start switch.
I get the idea of this, the thing is at least in my mind this does not seem to be connected to the issue I'm having.
I'm leaning toward the O2 sensor.
Any other suggestions or input would be great.
Thanks,
Andy
Old Nov 17, 2007 | 06:13 PM
brown 4x4's Avatar
brown 4x4
Is it running bad? Give us some more info on the symptoms. 67 is for the neutral start switch.
Old Nov 17, 2007 | 08:06 PM
subford's Avatar
subford
Service Code 67 indicates that during Self-Test, voltage was high on NDS (Pin 30) or ACCS (Pin 10) circuit.
Most of the time this comes up when someone runs the self-test with the A/C turned on.
Old Nov 18, 2007 | 09:10 AM
ANDEN's Avatar
ANDEN
The truck actual seems to run great.....well now that I think of it it runs great but then once the engine light starts flickering I would say it runs lean...(sluggish when I give it gas).
When I do the self test I do have the heater on, however doesn't mean that I might not have somehting triggering the aircon. I'll re try with everything shut right off.
At any rate what's your take on the possibility of the O2 sensor??
or possibley a dirty fuel injector, I've read that some guys put some STP injector cleaner in and away they go.
I have to admit the O2 sensor was from a junker. Tried to save a few bucks, maybe when it comes to these kind of things brand new is better.
Thoughts??
Andy
Old Nov 18, 2007 | 04:36 PM
ANDEN's Avatar
ANDEN
Okay so I turned the HVAC switch to off. (no heat or air con.)
An sure enough the 67 has gone. Which is good.
Now the only thing is I'm still getting the engin service light.
I'm going to change the O2 sensor with a brand new one.
If anyone has any other ideas let me know.
thanks,
Andy
Old Nov 18, 2007 | 05:33 PM
ANDEN's Avatar
ANDEN
Okay,
So I replaced the O2 sensor.
Still getting the Engine serive light coming on when I give it gas.
And after about 5 min of driving it seems to run a little rougher, some hesitation.
Tried pulling codes again and now I get an 11. (system pass)
So no what????
I picked up some fuel injector cleaner maybe I'll give that a go.
Any other ideas would be appreciated.
Andy
Old Nov 18, 2007 | 07:19 PM
brown 4x4's Avatar
brown 4x4
Have you checked KOEO (key on engine off) codes also? This will also give you the continuous (memory) codes. If the light comes on while running or driving there should be at least a memory code stored.
One other thing: Doesn't 89 still have both the red ENGINE light and the amber CHECK ENGINE lights? If so, the red one is not related to the EEC system and comes on for low oil pressure and high coolant temperature. Is it possible this is the light you're seeing?
Old Nov 18, 2007 | 08:12 PM
ANDEN's Avatar
ANDEN
Yes checked the KOEO codes. Nothing thier, this is were I got the 11.
Not sure about the Yellow and red service engine light. I check the owner manual and it certainly doe snot say anything about it.
At any rate I'm getting a yellow service engine light. Which flashes as I give it gas.
I was reading how someone else had a timiing issue which caused the engine light to come on. Seems like a simple solution so, I'll check my timing next and see what happens. After that I guess it's fuel injector cleaner.
I'm getting thier just seem to be taking the long way round.
Keep the ideas coming,
Thanks,
Andy
Old Nov 19, 2007 | 11:51 AM
ANDEN's Avatar
ANDEN
Update,
I re-checked the KOEO codes and sure enought there was a CM code 31.
This as I understand is related to the EGR valve.
So I'm going to get under way checking this prior to the injector cleaner.
I'll probably do that any way, one thing at a time.
Any suggestions when it comes to the EGR, itmes to look for etc.
thanks,
Andy
Old Nov 19, 2007 | 12:23 PM
Skandocious's Avatar
Skandocious
Pretty common for the EGR valve to fail. Most often the valve's internal diaphragm will become gunked up and cause it to stick in the open or shut position. In your case, it sounds like the valve is sticking in the open position and causing too much exhaust gas to be dumped back into the combustion chamber, this would cause the truck to run bad. A stuck closed valve shouldn't do any harm.
I've just read the text for code 31 and it says PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
EVP - EGR Valve Position sensor
PFE - Pressure Feedback EGR sensor or circuit
Sounds to me like your EGR sensor is bad. I had this same code when I purchased my truck and I bought a new EGR sensor on ebay for around $40, fixed the problem. On an 89 your EGR sensor should be mounted atop the EGR valve, like this:
I'm not entirely familiar with that design because my truck has two separate components for the valve and the sensor. Perhaps you have to purchase your valve and sensor in one piece. Maybe someone can chime in there...
Old Nov 19, 2007 | 12:36 PM
eco's Avatar
eco
Explain this.....how could the EGR valve be STUCK OPEN and have an EGR valve position sensor reading below MINIMUM VOLTAGE at the same time??
The further open the EGR is the higher the voltage at the sensor.
When the EGR is stuck open the motor will either not idle at all or have a rough idle, neither of which he is experiencing.
Old Nov 19, 2007 | 12:44 PM
Skandocious
Sorry I typed my first paragraph before I read what the code was... The latter half was supposed to be kind of an EDIT to the first part.
Old Nov 19, 2007 | 03:28 PM
ANDEN's Avatar
ANDEN
Great so it finally sounds like I'm on the right track.
I'll post more as I go.
Thanks for the info.
Andy
andy's2000
Feb 4, 2015 03:18 PM
surfref32
Aug 14, 2012 04:49 PM
andy wick
Jan 11, 2010 10:14 AM
aballard
Dec 29, 2006 10:34 PM
