Rear end problem
Old Nov 17, 2007 | 03:44 PM
i eat hybrids's Avatar
i eat hybrids
Rear end problem
When ever i turn left, right or accelerate, it feels like my rear axle is shifting. What do u guys think the problem is? I thought it could of been the u joints but i replaced them last year. Do u guys think that the axle is loose becaue it has blocks?
Old Nov 17, 2007 | 05:22 PM
kev03's Avatar
kev03
Thats a possibility, and check your shocks some times if they are bad they will make a sound like that. I had it happen to me in an old pickup truck.
Old Nov 17, 2007 | 06:10 PM
i eat hybrids
u think those could b loose?
Old Nov 17, 2007 | 06:30 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Matt,
Can you check the torque on the u-bolts?...that would tell for sure. Shoot some paint on the axle where it passes thru the U-bolts to make sure the axle isn't shifting...you know kinda make a stripe on the axle OVER the u-bolt...
Also...what tire pressures are you running?...I ask...because when I ran too high of pressure in my tires...it felt really squirely (sp?) in the rear...I backed off the pressure and things felt more stable...just a thought...
joe.
Old Nov 17, 2007 | 06:33 PM
i eat hybrids
Joe, i am running the psi that they are rated for (65). They are d's. Can u explain more about the paint?
Old Nov 17, 2007 | 06:42 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Matt,
I figure a picture was better...take a look at the u-bolt...do you see the greenish paint stripe on the axle and u-bolt...if you put that type of stripe on your axle...and it 'slides' in the u-bolt...you would see the stripe mis-aligned or all marred up.
Old Nov 17, 2007 | 07:23 PM
i eat hybrids
OO that picture makes alot more sense. For some reason i thought u were talkin about the u joint. I will do that and if it shifts then that is most likely why it is making that vidbration. Thanks for the tip!
Old Nov 17, 2007 | 08:59 PM
2xtremexj's Avatar
2xtremexj
I would check the torque on ALL of your rear suspension!! Most particularly the U-bolts and front and rear leaf bolts. If NONE of them are loose then I would starting checking your rear driveline again as well as your rear pinion.
I would check this stuff soon, the last thing you want to do is "spit a block" or damage the leaves. You can do alot of other damage in the process.
Let us know what you find.
Michael
Old Nov 18, 2007 | 11:40 AM
i eat hybrids
Ill let u guys kno, but i personally think it is the blocks because i use to do alot of rough off roading and the blocks havent been tightned since we put the lift on. Im going to check tomorow night
Old Nov 18, 2007 | 12:21 PM
2xtremexj's Avatar
2xtremexj
When you install blocks you need to torque properly, then re-torque after 100 miles, 500 miles, and periodically afterwards untill they are tight every time you check. If you haven't checked them this is VERY likely to be your problem.
Michael
Old Nov 18, 2007 | 12:54 PM
i eat hybrids
I hope it is my problem because id hate to have a ruined rear end. tightening 8 bolts is better then replacing a entire re end
Old Nov 19, 2007 | 04:14 PM
mntg718's Avatar
mntg718
what is the torque on those bolts???
Old Nov 21, 2007 | 11:44 AM
i eat hybrids
I got to look at the truck yesterday. The problem was that the axle was so loose. I could move both u bolts with my hands on the drivers sideof the axle
Old Nov 21, 2007 | 11:53 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
HOLY HEMORROIDS BATMAN!!! You are VERY LUCKY!
Glad you found it...that could have been very dangerous if it let go...for you, the Ex and all you share the road with...
joe.
Old Nov 22, 2007 | 12:01 AM
i eat hybrids
Ya exactly, im happy that it didnt come worse. I dont know how other cars would fair with a 10.5 axle comin down the road at u.
