return line replacement?
Old Nov 17, 2007 | 12:06 PM
illini aerofab's Avatar
illini aerofab
I am replacing the injector return lines and tees on a 91' 7.3. How do I get the line pressure sensor off the #4 injector to remove the tee?
Old Nov 17, 2007 | 02:40 PM
RLDSL's Avatar
RLDSL
I assume you have a van engine. Just remove the injector line above it, set it aside and then remove the adapter. you will likely need to hold the lower piece with another wrench to keep it all from turning
Old Nov 17, 2007 | 03:25 PM
illini aerofab
I figured it out. There was a plastic sleeve covering the hex on the adapter, above the cap. I wasn't sure and didnt want to break anything. I finally said screw it and pryed the sleeve off.
