Sponsored by: Real Truck
Passenger Power Window Problem
Old Nov 17, 2007 | 08:44 AM
daddy_k's Avatar
daddy_k
I have a very perplexing problem with my passenger window on my Supercab. The drivers side switch is inop and the passenger switch only moves the window down, the up position is inop. I connected the motor direct to the battery and it works in both directions. I thought the problem must be in the switch but after replacing both switches it still only goes down when using the passenger switch still will not go up, and the drivers switch does not work at all. Any idea's?
<!-- / message --><!-- sig -->
Old Nov 17, 2007 | 09:02 AM
Rongold's Avatar
Rongold
Check the wires in the convoluted rubber conduit between the doors and the hinge pillar. Most wierd P/W problems wind up being a broken wire in there due to constant flexing every time the door opens and closes.
RON
