what's this sensor for?
Old Nov 16, 2007 | 07:33 PM
viperbluelx's Avatar
viperbluelx
I was just looking around under the hood and found these vacuum lines someone had plugged off and I found the sensor where they should be plugged in. What is the sensor and why would anyone plug off the vacuum?
Old Nov 16, 2007 | 07:37 PM
twags6's Avatar
twags6
Auto lock hubs?
Old Nov 17, 2007 | 08:32 AM
nodakford's Avatar
nodakford
That is your hub lock solenoid. It used for the vacuum hubs. If someone replaced the OEM hubs with a set of manual hubs then there is no need for the vaccuum and they just plugged it there.
Old Nov 17, 2007 | 10:40 AM
mybigredford's Avatar
mybigredford
this is what i am thinking as well
i got auto hubs and had to change out that soleniod about a month ago cause my 4x4 stopped working
Old Nov 17, 2007 | 10:44 AM
clintbonnie's Avatar
clintbonnie
Your shift on the fly probably doesn't work.. You have to get out and lock in your hubs manually..
