Bilstein 5100 shock question
Old Nov 12, 2007 | 12:38 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I just ordered a set of Bilstein 5100 shocks for my truck. I have been reading on the internet and found that there is much discussion about how they are installed, boot up or boot down?
Anyone here have experience with them? How did you install yours? I saw a pic of a 4x4 truck with them installed boot up and there is discusssion all over about it.
Anyone?
These are the ones that I ordered (set of four though):
Old Nov 12, 2007 | 01:25 PM
Pocket's Avatar
Pocket
Install boot down. My truck is a 2002 and I'm running those exact same shocks.
You can tell by two ways, the easy way is the Bilstein label. The letters will be right side up when you mount (and the boot will be down). The other not-so-obvious way is the top and bottom mounts are different, just slightly. Compare to the old shock and you'll see.
Old Nov 12, 2007 | 01:30 PM
Texas Outlaw
Not a liberal...
Thanks, Curtis. I new someone here would know. Hopefully they will be here by Friday so my son and I can install this weekend.
We replaced the sway bar links this past weekend and it amazing how much better the truck handles in corners.
Old Nov 12, 2007 | 02:01 PM
lukecline's Avatar
lukecline
I just installed mine the same way the stock shocks were mounted. IIRC boot down on the front and boot up on the rears.
Old Nov 12, 2007 | 02:10 PM
clintbonnie's Avatar
clintbonnie
I just installed mine last month.. I don't think you can install them up side down anyway.. The mounting holes in the shock are different diameters on each end..
Old Nov 12, 2007 | 03:13 PM
santacruzf250's Avatar
santacruzf250
Be sure to just check the arrows like Pocket says. Bilstein actually makes upright shocks for certain applications also. I got into an arguement with a buddy about this once and ended up calling them to settle things once and for all. Depending on your application, mounting upside down/ right side up can vary. If Pocket has the same shocks then I'm sure he's right. Enjoy!
Old Nov 12, 2007 | 03:27 PM
Texas Outlaw
Not a liberal...
Pocket.....are all four shocks installed boot down on your rig?
Old Nov 12, 2007 | 04:32 PM
Pocket's Avatar
Pocket
Yes, they are all mounted boot down. The pic that you posted, there is the Bilstein label, and that label also has the model number. The labels can be read without me turning my head upside down... lol
Old Nov 12, 2007 | 05:34 PM
Texas Outlaw
Not a liberal...
Thanks, Bro!
Can't wait for them to get here.
Old Nov 12, 2007 | 06:32 PM
clintbonnie
My rear Blisteins mounted boots up.. and lettering was up right..
Old Nov 13, 2007 | 05:24 AM
Texas Outlaw
Not a liberal...
Thanks, Clint. I will look for that when I get them.
Old Nov 13, 2007 | 08:04 AM
Rick2001's Avatar
Rick2001
Mine are installed boot down.
Old Nov 13, 2007 | 08:59 AM
dyna's Avatar
dyna
Question
Are these shocks just for lifted trucks,or can they be used on a stock suspension?
Old Nov 13, 2007 | 09:34 AM
Rick2001's Avatar
Rick2001
They are for both
I have a stock suspension under mine. I do not recall the part numbers off the top of my head but I found them on their site very easy.
I am happy with the performance they gave the truck.
Old Nov 13, 2007 | 02:40 PM
Pocket's Avatar
Pocket
There are different model numbers depending on the size lift you have. Also it varies by year.... 2005+ have different shocks than 1999-04's.
