7.3 Problems
Old Nov 17, 2007 | 07:20 PM
F350-6's Avatar
F350-6
The factory oil gauges are more of an on off switch than they are an actual pressure gauge. Being 3 quarts low on oil could be your no start problem. What kind of oil are you running?
I'd go ahead and change the oil. While your at it don't forget to check the HPOP oil level.
Old Nov 17, 2007 | 08:26 PM
GeoffNJ's Avatar
GeoffNJ
I had a similar problem a few weeks back. Check the oil level in the HPOP. It's simple and it may just be your problem.
Old Nov 18, 2007 | 11:47 AM
not88's Avatar
not88
another question
how do you check the oil level in the HPOP?
Old Nov 18, 2007 | 12:14 PM
GeoffNJ's Avatar
GeoffNJ
On the top of the HPOP (just in front of the fuel filter) there is a small, lpug with a hole for an allen key. Take out the plug and dip something in there. The allen key will work if it is long. The oil should be just about 3/4" from the top.
Fusion7.3
May 30, 2014 10:51 AM
Fusion7.3
May 29, 2014 09:31 PM
Dirt Racer96m
Apr 15, 2014 11:44 PM
Keith73
Mar 27, 2008 04:07 PM
bushwick56
Nov 4, 2007 12:12 AM
