Sponsored by: Auxito
00 f150 will not start
Old Nov 16, 2007 | 05:26 PM
mdgeers's Avatar
mdgeers
Hey all, I have a 200 F150 with 135k and a 4.6 that will not start. It starts to turn over but then nothing. I took the battery in to get it tested and it had a bad cell so I replaced it but it still will not start. I took the starter out and ran a jumper across it and the starter works but the truck will still not start. Any help would be greatly appreciated.
Old Nov 16, 2007 | 05:56 PM
ididntdoit99's Avatar
ididntdoit99
i've seen it before where you take the starter out and it work's fine off of the vehical, but will not work when you actually put it on there.
when we changed my starter last year it worked fine when we took it out, we weren't sure what the problem was. But we slapped the new one in anyway since we already had the old one off. And it has been fine since.
Old Nov 16, 2007 | 06:40 PM
projectSHO89's Avatar
projectSHO89
Perform a voltage drop test on each cable while cranking to see if you have a bad cable or connection.
Steve
