What than the dual battery on you deisel ? I never had any problem with them . I even put that type setup in some gas jobs for plow use. What seems to be your problem??
Lasted 20 years . Get another set and last another 20. Just kidding
Get the we have been putting those optima Batterys and mount side by side after making tray in stock location . on passengers side. It there or get a mount box kit and put on frame rail under bed or the like .
Honestly, if you don't mind the price of them, Optima batteries are the absolute BEST way to go. So far as I know, there isn't a better automotive (or marine for that matter) battery on the planet.
The only disadvantage to an Optima is the initial cost. They are MUCH better for you in the long run though, so they would probably wind up saving you money on the long term.
Mine was one on passenger and 1 on driver but that was on early F truck . The optima being smaller you canfit bot in stock position with a home ,made mount.
