cluster warning
Old Nov 15, 2007 | 10:23 PM
dreo2003's Avatar
dreo2003
Angry cluster warning
'93 cluster panel will not work in '95. learned the hard way tonight.
Old Nov 15, 2007 | 10:46 PM
17fordguy's Avatar
17fordguy
it will just requires rewiring i used a 94 in my 96
Old Nov 15, 2007 | 10:51 PM
dreo2003's Avatar
dreo2003
oh cool! what do i have to do?
Old Nov 15, 2007 | 10:57 PM
17fordguy's Avatar
17fordguy
i had a diagram of what wires to swithc but i donyt know what i did with it ill take a look around tomorrow and see if i can find it
Old Nov 15, 2007 | 11:06 PM
dreo2003's Avatar
dreo2003
after some searches, i see that i'm not the only one that had this problem. the wiring diagram would be great. thanks 17fordguy
also, can i get my real mileage back?
Old Nov 15, 2007 | 11:43 PM
17fordguy's Avatar
17fordguy
yes disasimble the cluster and remove the spedometer part and reinstall in new cluster
Old Nov 16, 2007 | 08:37 AM
dreo2003's Avatar
dreo2003
my cluster has no tach and the new (old) one does. Will i still be able to swap internals and retain my mileage?
EDIT: Ok i found out that i can swap the internals to retain my mileage. all i need now is instructions on the re-wiring procedure.
Old Nov 16, 2007 | 09:38 AM
subford's Avatar
subford
Sure, just swap the PSOM from one to the other. The mileage is stored inside the PSOM.
As far as rewiring, yes you can rewire it to work but some of the light indicators will have the wrong lettering for them.
Just swap the wires from one plug to the other and/or on the same plug as required.
The 1992 & 1993 Clusters are the same and the 1994 & 1995 clusters are the same.
The 1993 cluster.
The 1995 Cluster.
Old Nov 16, 2007 | 10:32 AM
dreo2003's Avatar
dreo2003
subford, those are the diagrams i wanted, thanks. but i do remember reading that the clusters on the f series trucks are different than broncos. for example, above it says that pin 1 on the 250 harness is not used but on the '93 cluster that i have, pin 1 is used and pin 2 is unused. my '95 has pin 1 and 2 used but 3 is unused. can i just pull the wire out of slot on the harness and put it in another or will i have to cut, strip, and solder?
also, since pin 3 on my 250 harness is not used, there is no contact terminal on it. could i also swap this from pin 2 to pin 3?
Old Nov 16, 2007 | 11:29 AM
subford's Avatar
subford
I just looked at the pin-out for the 1993 F series and they are identical to the 1993 Bronco that I posted. So I think who ever posted that, they are wrong.
Are you saying you have a cluster that uses pin #1 and not pin #2 on a 1993 cluster?
I am looking at a non-tach cluster out of a 1995 F150 and it uses pins 1 to 4, 6-8, 11-14 of C250 so I have no idea what you are talking about.
Old Nov 16, 2007 | 11:39 AM
dreo2003's Avatar
dreo2003
Ok, im glad to hear the bronco is the same. so i can print out those diagrams and match the wires. I was just stating the wire configuration from memory but i guess i remembered incorrectly. if you're looking at a '95 C250 i'll take your word for it. so i have the diagram aspect out of the way all i need to worry about now is the actual swapping. do i cut, strip, and solder or can i just pull the wire from one harness slot to another? also, those unused pins are missing contact terminals so can i swap those too? thanks for your help so far by the way.
Old Nov 16, 2007 | 11:54 AM
dreo2003's Avatar
dreo2003
from studying the wire diagrams i have two questions. all the curcuits match except "unique ground to gauges." It is curcuit number 875 on the '95 and it is curcuit number 570 on the '93. is this ok?
also, i see that some wires go to multiple pins. do i splice this wire or solder a connecting wire from it to the necessary pin(s)?
Old Nov 16, 2007 | 12:11 PM
subford's Avatar
subford
Just pull the wire out put it in where it needs too go.
I do not think you will have any unsed contacts.
Old Nov 16, 2007 | 12:17 PM
subford's Avatar
subford
Yes it is OK, some wires will have differnt wire numbers, just match the functions.
I take it you are talking about circuit 640, yes you might have to splice this wire to another wire and snap it in.
Old Nov 16, 2007 | 03:57 PM
lostin90s's Avatar
lostin90s
Yepper you can . Its just easy to get right one. Allot of guys r picky about all light etc being right. Hope you get fixed.
