78-79 ford help
Old Nov 15, 2007 | 07:30 PM
Xistenz's Avatar
Xistenz
78-79 ford help
Hi guys i am looking to buy a 78/79 ford and i have run nto a few questions along the way. by the way i am interested in 4x4 models only. First what is the dieffernce between the f100, 150, and 250? and the option like explorer, custom, ranger? I would really like to get a reg cab and am looking to lift it using the CAGE offroad 4" lift. This lift works with the front coil spring setup but i know some trucks had leaf springs up front. which setup would you recommend for a tough trail truck/daily driver. Also if i went the way of the coil spring front setup i would like to drop a dana 60 front diff. in. i heard there was a kit to make the diff work with coil springs/radius arms? any help or links to the informatin would be greatly appreciated, i'd like to do things right the first time. Thanks
Old Nov 15, 2007 | 08:06 PM
2classics's Avatar
2classics
Hello, the best advice on the site is to do a search for each question. These things have been covered several times in great depth. All these trucks are tough. The easiest way to get a d60 in front is to buy a 250 with one or all 350s came with them. 79 is the first year for 4x4 f350. All 250/350s came leafs in front. 100/150 4x4s had coils. Mods. for the truck are based on your abilities, fundsand use of the truck. These things are not cheap once you get one. Everyone here will agree on that. Always room for improvement, and always room in the gas tank.
Old Nov 15, 2007 | 08:08 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
Please don't be afraid to make one thread per topic and title that thread with thre topic in it.
You have so many questions in one thread it will take some time to sort out.
Basically F100,F150,F250,F350 are just GVWR or weight related models.
They all share the same body and trim
Custom,Explorer,XLT,Lariat are TRIM LINES.
With a Custom being a truck you could build anyway you want.
Explorer was a special marleting trim line
XLT was standard Luxury Trim Line
Lariat beginning in 78 became an even more Standard Luxury Model .
You can read about them on my website here.
http://www.clubfte.com/users/mil1ion...urePhotos.html
and 79 brochure here.
http://www.tocmp.com/brochures/Ford-...ure/index.html
Old Nov 15, 2007 | 09:11 PM
starmilt's Avatar
starmilt
If you want coils on the front has to be 150 d60 on a 150 expensive mod then you will need a rear to match. why you stuck on coils only the thing better is ride. cheaper to lift a 250 or 350 or 73 to 77 highboy already lifted some had d60 fronts.
Old Nov 16, 2007 | 11:41 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
You could have one of the big name axle companies custom make a D60 fit in a half ton but it would be really expensive. An alternative to that is to just beef up a D44 with stronger components.
Old Nov 16, 2007 | 10:10 PM
Xistenz's Avatar
Xistenz
Would like the coils up front as this truck will be used mostly as a daily driver. also i have heard nothing but good comments about the cage offroad 4" lift
Old Nov 16, 2007 | 10:32 PM
Dustin1690's Avatar
Dustin1690
Basically a F100 is a F150 but just with fewer mor leaf sprins more of a light duty pickup F150 is a 1/2 ton F250 is a 3/4 ton and F350 is a 1 ton basically as the numbers go up they weigh more like 250 and 350 are more beefed up in the suspension
Old Nov 17, 2007 | 05:05 PM
JBradley500's Avatar
JBradley500
i always thought that the f100 was the same as a f150 but had different emissions.
Old Nov 17, 2007 | 07:05 PM
ErrorS's Avatar
ErrorS
I think F100 has 2.5'' springs in the rear..
and are you all sure ALL F250s had leafs in the front? I thought so too, but there's an F250 Ranger for sale locally that has coils in the front.. Has a 460, 2WD, dual tanks..
Old Nov 18, 2007 | 08:20 AM
79f3504x4's Avatar
79f3504x4
2wd f-250 came w/coils on front, 4x4 had leaf
.87-ford
Offroad & 4x4
31
Aug 2, 2011 02:12 PM
gittinwidit
All Things Towing
Aug 2, 2006 09:03 AM
73highboy4x4
1978 - 1996 Big Bronco
Jan 4, 2006 02:48 PM
Rediranch_too
May 5, 2004 04:22 PM
kuss
Feb 24, 2003 06:48 PM
