door lock actuators
Old Nov 15, 2007 | 06:16 PM
foxdog's Avatar
foxdog
door lock actuators
i just bought a 1990 f250 supercab 7.3l diesel and neither of the door locks will move up and down manually or with either switch. a mechanic told me i needed new actuators. I got replacement actuators but i am having trouble getting the old ones out and i dont want to break anything. Has anyone done this before? What is the best way to do this?
Old Nov 15, 2007 | 07:42 PM
lostin90s's Avatar
lostin90s
Remove door panel
drill out rivet holding actuators.
Get small mirror to see how linkage is hooked up
unbolt door latch for a little room. the actuator linkage should come off . I cant remember if it has one of those plastic holders that you have to turn to remove . I think it does.
Reinstall . If you can get a camera in there and take pictures. Those linkages can be a bear.
It been 5 yrs so I bet I missed something . I know I removed latch. Take time itsjust a no room so dont cu yourself I cut pc of small hose lenthwise and slip over any sharp edges . No cuts is good Have a good one.
