front end noise
Old Nov 15, 2007 | 05:30 PM
TB55's Avatar
TB55
front end noise
I have a 2000 XLT 4x4, and recently the front end starting clunking.Small bumps big bumps it doesnt matter it rattles pretty good.Shocks are good, ball joints are good, u-joints are good, sway bar seems tight.Anybody else go through this or any ideas?
Old Nov 15, 2007 | 05:41 PM
ASITool's Avatar
ASITool
It's really easy to eliminate the swaybar by disconnecting one side then testing. Is your vehicle lifted?
Old Nov 15, 2007 | 06:16 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Is it when you are going straight or turning?
Wheel bearing going bad?...just a thought since you mentioned my other suspects as being good...
good luck,
joe.
Old Nov 15, 2007 | 06:40 PM
TB55's Avatar
TB55
theres no lift kit everything looks stock.I jacked up the front end and checked for play everything seems tight.It rides like the shocks are bad, but I dont think they are.I've only had it a year, maybe it's supposed to ride like a bus (ha ha).
Old Nov 20, 2007 | 04:02 PM
sbmoto's Avatar
sbmoto
Springs?
Sounds like your springs are causing the frontend to bottom out-is it hitting the bumpers above the springs-Mine does if I hit a speed bump too fast.
