Sponsored by: Real Truck
reverse/flood light
Old Nov 24, 2007 | 07:57 PM
  #31
Beerstalker's Avatar
Beerstalker
Originally Posted by dadsgreenpsd
Isn't another relay needed for the backup light if you use the trailer plug? I mean in the factory relay socket under the hood.....
Yes there is. One-wicked-element, check under your hood in the relay boxes by the master cylinder. There should be a 20amp mini fuse in position 4, and a relay in position 38. Without these, I doubt the backup light would work automatically in reverse.
Old Nov 25, 2007 | 06:16 PM
  #32
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I installed cheap Harbour Freight fog lights, $10.00, under the hitch cross bar, tapped into the reverse wire for the trailer plug and then upgraded to 100W bulbs. No extra relay, no extra switch (I am going to add one for loading the snowmobiles) and no problems. I have about $22 and some time into my system and boy does it make it bright back there.
tkmitchell
Jul 9, 2017 06:32 AM
Jesse73iditurbo
19
Dec 8, 2016 01:25 PM
thegenco12
Appearance & Dress-Up
Apr 20, 2016 10:55 AM
aramirez
Jan 5, 2016 09:48 AM
SuperMike
Jan 22, 2013 04:06 PM
