Sponsored by: Real Truck
reverse/flood light
Old Nov 16, 2007 | 02:23 PM
WhiteEx's Avatar
WhiteEx
I bought a set of cheap fog lights ($29) from an auto parts store and mounted them upside down to the bottom of the hitch cross bar and as far outboard as I could. Both of them are pointing slightly outboard also. Then I just tapped into the reverse wire. It is like having a set of headlights back there. Don't have my camera at work, so I can't take any pics. The whole installation took less than 30 minutes.
Old Nov 16, 2007 | 02:44 PM
thedaddycat's Avatar
thedaddycat
That plug in light is neat and a fast and easy solution. There's just one downside I can see to it, it unplugs just as fast and easy as it plugs in. The odds of it sprouting legs seems kind of high....
Old Nov 16, 2007 | 04:21 PM
mpbpulaski's Avatar
mpbpulaski
wow - another great solution, if only I didn't tow so much... it's amazing the cool things I find out about on this site that I might not have found without it.
on another subject: thedaddycat, I saw the c-betr mirrors in your signature and looked those up. How do you like them? Are they worth getting?
Old Nov 16, 2007 | 11:32 PM
rikosintie's Avatar
rikosintie
I have had the C-betr mirrors for about 3 years and love them. They have held up well and provide a great view along the side of the truck. Well worth the money.
Michael
Old Nov 18, 2007 | 11:05 AM
bbender85's Avatar
bbender85
i've run the same lights as bearhunter now to for quite awhile, and i swapped in 100w bulbs before the install; my only gripe is the beam pattern is focused, not as much of a flood pattern as i hoped for.
i have a single 55w farm light mounted on the inside of the top of my topper i run during duck season, and that lights up everything behind me like the sun, nice for launching the boat before dawn.
Old Nov 18, 2007 | 11:32 AM
DCSpecial's Avatar
DCSpecial
Yep, you'll get the best lighting that I've seen out of a flood light (like the kind you would put on heavy equipment).
Hella has some Xenon (HID) Floods that are super bright.
I use PIAA 1500 backup lamps:
Old Nov 18, 2007 | 05:28 PM
britt's Avatar
britt
I have seen those plug in lights at lowes .-britt
Old Nov 18, 2007 | 06:11 PM
rikosintie's Avatar
rikosintie
I saw the plug in light at Autozone this morning.
Michael
Old Nov 18, 2007 | 07:30 PM
tac53parsons's Avatar
tac53parsons
Originally Posted by NJF350SD
This is awesome. Gotta get me one. Do they sell direct?
Also available at Lowes.
Old Nov 19, 2007 | 09:09 PM
one_wicked_element's Avatar
one_wicked_element
I picked one up from Autozone (the one that plugs into the 7 prong trailer harness) for $18. I'll give it a go for a week and see if I like it.
I'll take some pictures of it was well.
Old Nov 23, 2007 | 04:22 PM
one_wicked_element
UPDATE: This does not work.
The install was simple. Open the package, and plug it in. Make sure to "lock" it in. The 7 prong flap / cover holds it in. I drove around for a few days and no problems with it moving, or falling out.
It has two settings:
1. Always on.
2. On with Reverse.
The "always on" settings works fine. You just twist the head, and it turns on (as long as your lights are on). The "Reverse" setting does work. It just stays off.
I tested it on my truck (01 F-250 SD) and my brother in law's 97 F-150. Both with the same results. It will get power for lights, but will not turn on with your reverse lights.
I then returned it, and tried another one (to see if I had a bad one). The new one did the same thing. Would work in the "light" setting, but not in the "reverse" setting.
I wanted to test it on another truck, but couldn't find one with a harness. So, I don't know if it's a "Ford / Wiring" thing, or if it's a "Me" thing.
Does anyone know if they wired the older trucks for reverse?
Old Nov 23, 2007 | 04:50 PM
dadsgreenpsd's Avatar
dadsgreenpsd
Isn't another relay needed for the backup light if you use the trailer plug? I mean in the factory relay socket under the hood.....
Old Nov 23, 2007 | 10:46 PM
  #28
mpbpulaski's Avatar
mpbpulaski
on my '05 the wire is there and functional. on the '06 chassis cab the wire was in the bundle but never hooked in to the socket, which was easily fixed. I discovered this while trouble shooting trailer brakes. which is when I also discovered that the built in brake controller does not apply the trailer brakes when you are not rolling, unlike a normal electric brake controller, but that is another topic... so anyway you may have the wire but it's not hooked into the socket
Old Nov 23, 2007 | 11:37 PM
  #29
one_wicked_element
It would just be hanging around back there, and just needs to be plugged into it?
Old Nov 24, 2007 | 12:56 PM
  #30
mpbpulaski's Avatar
mpbpulaski
Thats basically how mine was, just hanging in the bundle but not hooked into the socket. but after I replied last night I realized that my chassis cab (which has a flatbed on it) has been worked on by the aftermarket installers to but the bed on. they probably kept the ford socket and re-wired a different one to the truck, not bothering to hook up the back-up wire since it is rarely used on a trailer. the rest of the flatbed has extra light hook-up plugs every where - some kind of universal wire harness the installers use I guess. I could be a rolling light show if I put a light on each available spot.
So maybe your older truck doesn't have the reverse light wire from ford. I had a '97 with factory tow package but since I never needed the reverse wire I can't say wether it was there or not.
