Timing Chain or Gear?
Old Apr 25, 2002 | 08:57 AM
gdavis2265's Avatar
gdavis2265
Old May 4, 2002 | 11:07 PM
chickenmanq's Avatar
chickenmanq
I have a '63 Ford with the 223 6, and in one of my wonderfully specific manuals (yeah, right) it says the engine has timing gears. I realize all I have to do is take off the front cover and check but I really don't want to right now, and seeing as I'm sitting in front of the computer, I figure one of you knows.
I thought only Internationals and older Mercurys had timing gears, and that this engine had a timing chain. Am I wrong? It only has 4 degrees of play. I've been told that's not a bad amount. My only worry is that timing gears would be harder to find than a timing chain. I plan to use it enough to need one or the other sooner or later.
Old May 5, 2002 | 07:25 AM
larry derouin's Avatar
larry derouin
Most all of the inline 6's I've ever torn into (Ford, Chevy, Studebaker) that had cam in block were timing gears, no chain.
I'd think your 223 would be same.
Larry
Old May 5, 2002 | 09:42 AM
mantta's Avatar
mantta
According to an old Motors manual I have the 223 cu in six has a timing chain. The 240 and 300 have a gear driven camshaft.
Old May 5, 2002 | 12:27 PM
chickenmanq
Well, with that, I guess I'll take off the cover when I have time and let you guys know.
Old May 5, 2002 | 06:13 PM
bhabben's Avatar
bhabben
chickenmanq,
I looked in my Ford Service Manual, and sure enough its a CHAIN.
I would have never guessed; every other six I can think of uses a gear set.
One more thing to worry 'bout....
Brett
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
