offy vs clifford
Old Nov 15, 2007 | 12:39 PM
mousetrap65's Avatar
mousetrap65
offy vs clifford
which one will work better for cold winter use
planning to use efi man with factory style down tube and unvesal cat
on rebuilt motor
Old Nov 23, 2007 | 06:44 PM
Harte3's Avatar
Harte3
Either one will work. The Clifford with the water heat arrangement built in or the Offy which water heat to it can be simply arranged. You are gonna need heat to the manifold or a water heated carb spacer in WI.
Old Nov 23, 2007 | 07:17 PM
mousetrap65
think I will go with clifford the extra 10 spot seems more than worth the hassel
of tring to simply arrange something
Old Nov 23, 2007 | 07:22 PM
buckingbronco1's Avatar
buckingbronco1
i have the offy with a 400 carter and hooker header and it works great. it's also for sale - cheap!
Old Nov 23, 2007 | 08:50 PM
Harte3's Avatar
Harte3
I think the Clifford probably distributes heat through the manifold better than the Offy.
Old Nov 24, 2007 | 02:56 AM
BMW2's Avatar
BMW2
How much is cheap and where are you located? Sorry don't mean to hijack.
Old Nov 24, 2007 | 10:51 PM
Harte3's Avatar
Harte3
If you are going to rebuild, get a mild port/polish (port match with manifolds) on the head along with a 3 angle valve job while you are at it to get the best from your induction and exhaust changes. The stock 240/300 head just doesn't flow very well.
Old Nov 25, 2007 | 08:05 AM
buckingbronco1
carb - needs to be cleaned/rebuilt
intake manifold
hoker header
$350
