Low Power
Old Nov 15, 2007 | 09:03 AM
RichardBrown42's Avatar
RichardBrown42
Low Power
After my 6.0 Diesel sits over night or all day without being started, it has no power. After engin runs about 10 min it has plenty of power. Can anyone solve this problem?
Old Nov 15, 2007 | 10:59 AM
drakul20us's Avatar
drakul20us
How about a little info on the truck? model, year, mileage, mods, tunes?
What do you mean 'no power'? What does that constitute? Slow of a cold start? My truck is always slow after a cold start, as the engine works and warms up the oil it becomes better in speed and response. You can't expect the truck to start in the morning and fly around town right away.
Old Nov 15, 2007 | 11:14 AM
Jocaren's Avatar
Jocaren
agreed, you need to let your truck warm up, i usually do not romp on it until the stock coolant gauge is half staff and my trans temp gauge is at least on 120!
Old Nov 15, 2007 | 11:44 AM
18vtx00's Avatar
18vtx00
we need some more info, the MY truck does nto help much. what is is and what mods if any?? they all need to run a few minutes after intial start up.exspecially in the colder temps.
Old Nov 16, 2007 | 08:16 AM
RichardBrown42
Ok Guy's,
I wasn't thinking the model made a differance, but I own a 2003 F-250 SD, equiped with the 6.0 Power Stroke engine.
I really don't "Romp" on it right after a cold start. However after the vehicle sits for "say" around 2-3 hours I can start the engine and drive off at a moderate speed. When the vehicle sits for a long period "say" over-night, then it has LOW power. The vehicle acts as if the accelerator isn't even connected. It is sort of like driving off at idle speed. However when you continue to hold the accelerator down (for maybe 50 feet) the engine picks up and the vehicle jumps foward. The next stop then start it has LOW power again. This goes on for around 4-5 miles. It's like the fuel system is losing prime.
Old Nov 16, 2007 | 09:29 AM
npccpartsman's Avatar
npccpartsman
Sounds like you might have injector stiction to me. Have you had the latest reflash that helps with cold start's? If not you might consider that before you let someone tear into it for an unnecessary repair. A reflash typically will cost you about 1 hour labor (takes about 10 minutes or less to do).
Old Nov 16, 2007 | 02:33 PM
18vtx00's Avatar
18vtx00
yeah an hour or less charge, but the 6.0L takes about 30-40 minutes because you are flashing 3 modules(FICM,TCM,PCM) and so many key cycles on and off about 15 times.. way too many key cycles but they are needed to make sure the modules do not lose communication w/ each other.
May be stiction, it is a good idea to get the heat inductive anyways to avoid stiction.
smoore0531
May 28, 2015 02:14 AM
jmahle67
Nov 29, 2014 12:46 PM
btsb032304
Oct 25, 2014 06:45 AM
ggirten
Oct 12, 2011 05:13 PM
Jims05Screw
2004 - 2008 F150
Oct 18, 2005 03:31 AM
