Generic engine cleaning question
Old Nov 15, 2007 | 05:37 AM
tommythomasson's Avatar
tommythomasson
I've got the motor out for various major repairs (84 F150 302 2bbl). It has been leaking oil since 1988. As you can imagine, it looks like it has been dipped in sludge (the sludge is 1/2" deep in places). It also had an exhaust leak which has added 3 tons of soot to the top of the motor and the entire engine compartment. (I wish I had taken pictures of my clothes atfer I got it out) I'd like to do a thorough cleaning of this thing before I begin disassembilng it. Does anybody have any tricks for cleaning caked on oil & soot?
I've considered steam cleaning & degreaser, and just putting a lot of cardboard underneath to catch the gunk. Was curious as to what you guys think before I do one of these. Also considered just biting it and cleaning the parts individually as they come off.
Old Nov 15, 2007 | 11:11 AM
mousetrap65's Avatar
mousetrap65
scrapers wirebrushs time
i would clean first . start with scrapes then brush them degreaser and steam
Old Nov 15, 2007 | 12:20 PM
Franklin2's Avatar
Franklin2
If you are going to rebuild it, you can get the engine shop to dip the parts in their cleaner without having to worry about the mess. You would just have to clean up a few odd pieces here and there.
That gunk engine brite works pretty good too.
Old Nov 15, 2007 | 09:23 PM
mousetrap65
i would still clean before taking apart you can learn stuff and its good practice fo being reeelaly cleeen at time to put back together.
Old Nov 15, 2007 | 09:26 PM
stroked 347's Avatar
stroked 347
Go to the dollar store and buy some oven cleaner. Spray it on, let it sit a while and hose it off...
94' 460 F350's Avatar
94' 460 F350
steam cleaner would work the best or a hot water pressure washer, this stuff called "oven clean" works 10 times better than engine degreaser, any oven self-cleaner spray works excellent
Old Nov 15, 2007 | 09:40 PM
gearhead351's Avatar
gearhead351
EASY OFF OVEN CLEANER! works great! stuff is about as potent as rat poison but it cleaned everything off!.....including the paint under neath the grime!
Old Nov 16, 2007 | 12:13 AM
Piffery1's Avatar
Piffery1
I'd use GUNK first, let it soak in good and then have it steam cleaned.
Old Nov 16, 2007 | 07:05 AM
tommythomasson
I probably never would have thought to use oven cleaner. I'll probably use some combination of all as it is pretty nasty. Thanks for the ideas.
Old Nov 16, 2007 | 09:35 AM
Franklin2's Avatar
Franklin2
I think I am going to have to try the oven cleaner myself. Never have used it before.
Old Nov 16, 2007 | 12:33 PM
hoxiii's Avatar
hoxiii
seeing as how the motor is out of your truck whis may or may not work, but here goes.
I typically attack with a scraper to get the big chunks and then spray it down with oven cleaner. Next I load the engine in the bed of my truck and go to the local car wash (either a quarter wash or a drive through) and let it get blasted away.
If you're tearing it down anyway it won't matter if some water gets inside and the drivethrough wash is really handy for when it's cold out or you just don't feel like getting too terribly dirty.
Justin
Old Nov 16, 2007 | 08:32 PM
bob_351's Avatar
bob_351
Just be careful with the oven cleaner it is really harsh on your skin and it will strip paint. Most automotive degreasers are like that as well but i have found oven cleaner is a lot stronger.
Old Nov 16, 2007 | 09:16 PM
mousetrap65
oven cleaner wouda tunck it ??? will have to try ,not throing scrapers away just yet
Old Nov 17, 2007 | 11:04 AM
big hoss 29's Avatar
big hoss 29
I used oven cleaner on my engine when I took it out a couple years ago and it works great. Easy-Off is my weapon of choice. Like gearhead said, it's nasty, nasty crap but it'll strip grease off an engine like nothing else.
If the grease and oil is really heavy in a few places, you might want to scrape the thicker stuff off before the oven cleaner gets sprayed on so the motor gets uber clean.
Old Nov 17, 2007 | 09:47 PM
mousetrap65
wow that stuff works. dont get in cuts wow that stuff hurts small hole in gloves big wow ps buy your own wife got wow mad
JPMallory
Jun 17, 2014 02:21 PM
1974 f100
Feb 16, 2014 06:33 PM
creich68
2009 - 2014 F150
Feb 18, 2013 06:13 PM
AbandonedBronco
56
May 27, 2011 11:23 AM
BigShelby
Oil & Lubrication
17
Jan 23, 2004 05:54 PM
