Any SD owners with Warn Hubs and Alloy Wheels
Originally Posted by THE KING
No.... I still have vent and floor. Maby the hose is clogged?
This doesnt make sence tho. It went into 4x4 great and i snapped a hub pulling the truck out of a ditch. But it had a hard time going into low. Now i have the warns and it goes into 4 low but i still have vent and everything. Il have to check this out tomorrow. The are suppose to be blocked off right?
Received 3,248 Likes
on
Originally Posted by akatrd
TJ how does the rear 05 cap look and feel on an 02. Basically will the 05 caps fit on an 02 front and rear? Did you just put the 05 caps on the front only or did you put them all the way around?
i have not found a set for the rear yet, cause i keep on forgetting to look for them.
stevestroke01
01-19-2012 08:27 PM
klemn5
09-04-2011 01:15 PM
