Sponsored by: Real Truck
clear cab lights??
Old Nov 14, 2007 | 10:10 PM
Trav460's Avatar
Trav460
clear cab lights??
i bin on the road for a while and seen a truck had clear cab lites... curios if n e one has these or no's where to find them? i have no lights on my truck now so i wana put 7 lights up there in clear to match the front clear markers.. and preferably LED's but not gona be to picky.. the only reason i get this idea is because i have the set up on my peterbilt.. and it fills in that gap of 5 lites every truck has. i also was thinkin actual peterbilt cab lites.. but there to long as i have a sunroof.. thanx for n e help
Old Nov 14, 2007 | 10:38 PM
07psdrookie's Avatar
07psdrookie
I think Recon lighting has what you're looking for. Try checking out www.streetbeatcustoms.com/recon-lighting.html. They have a bunch of clear, LED, and smoked lighting accessories for our trucks. Hope this'll help.
Old Nov 15, 2007 | 05:52 AM
BGMSPD's Avatar
BGMSPD
as 07psdrookie said, Recon has quality factory replacement bulbs and covers for cab lights. They are not LED and do not come with the mounting base. they are just lens covers. so they would somewhat solve your problem, your still gonna need the factory base and wiring. Most of Recons products are LED however these are not yet. I have many of their products and I'm happy with the quality. hope this helps
Old Nov 15, 2007 | 11:52 AM
Beerstalker's Avatar
Beerstalker
As far as adding the lights check out this thread. It has lots of information including the part numbers.
https://www.ford-trucks.com/forums/6...ce-lights.html
You will have to splice in some wires if you really want to add 7 lights, since Ford only does 5.
As the others mentioned Recon is the company that makes the clear or smoked covers with amber bulbs. They sell them in sets of 5 though, so you would have to buy two sets to get 7 covers.
http://www.gorecon.com/products.php?p_cat=28
Old Nov 15, 2007 | 11:41 PM
Trav460's Avatar
Trav460
thanx for the replys.. i'v bought lots off streetbeatcustom.. i should of thought of them. ill look into thanx
