I hope this guy's not for real....I know I've done redneck things but you can't actualy think running sand through your intake could do you any good and if you do, I've got some water front property for sale in florida...besides Man if your apart of this Ford Forum you must have figured that you can ask any question and get pretty good awnsers these guys know there chit
Yeah, I am late to this, but I knew that was gonna be full of it. Not even a total knuckledragger is that STUPID, but it was funny as he!! the way it was written. Thanks for the laugh.
well I think what we have here is a case of over siliconization of the compression ignition chamber, the reverse procedure for this is to apply a WHOSYERGENEDADRAMAIR, to the tail pipe at maximum thrust. by doing so you also polish the trailing edges of the ports which will improve laminar velocitific absolute drive efficiencey.
also check your SCA's when done to make sure your level is correct. I would also send an oil sample to blackstone, and tell them that you suspect your silicon levels to be high and could they confim.
ther real bad thing about this whole deal is there is probably some Dumb A$$ who has done it.
