brake booster
Old Nov 14, 2007 | 04:59 PM
slick-fitty's Avatar
slick-fitty
brake booster
i got a 2000 ranger 4.0 i just replaced and was wondering what the push rod length is "supposed" to be. the booster i replace had exactly 5 threads out and adjusted my new one the same
Old Nov 14, 2007 | 05:02 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2009 F150 forum.
Old Nov 15, 2007 | 07:10 AM
pawpaw's Avatar
pawpaw
With vacuum applied to the new booster & about 5 lbs of force on the boosters push rod to seat it, the distance from the high step @ the base of the mounting bolts, to the end of the seated push rod, should be one inch, +- almost nothing!!!!
So if your brake pedal tavel was ok before & you've adjusted the new boosters push rod to the same seated throw height, I should think your good to go.
If you find you don't like the pedal feel, travel, or height, or the pushrod height is too high & the brakes don't fully release & are dragging, the master cylinder can be unbolted & carefully set aside, without disconnecting the brake lines, to make another pushrod adjustment.
Let us know how it goes.
Old Nov 15, 2007 | 07:06 PM
slick-fitty
i really dont know what you meant by high step, i tryed to measuring everything on there nothing comes out to an inch. from the back of the lock nut to the tip of the push rod is 3/4 should i pull that out to one inch ?
Old Nov 15, 2007 | 08:58 PM
pawpaw's Avatar
pawpaw
My manual showes the one inch height is measured from the surface of the boosters housing, at the base of where the master cylinders mounting studs come through, to the tip of the boosters actuating rod, with vacuum applied to the booster & about 5 lbs of inward force applied to the rod.
This inward push on the boosters rod, simulates the master cylinders return spring pressure & makes shure the rod is fully depressed, so your accurately setting the one inch height.
If the rod sticks out too much, the brakes won't fully release, when you take your foot off the pedal.
If the rod doesn't stick out enough, you won't have any brakes, when you apply them.
Rusty_S
Oct 1, 2016 11:34 AM
Jrobole
Jun 3, 2016 07:49 PM
candoo
Jul 5, 2014 10:26 PM
Furniture Doctor
Mar 26, 2013 08:39 PM
