cheap mods
Old Mar 20, 2002 | 11:13 AM
DrFord's Avatar
DrFord
cheap mods
Old May 16, 2002 | 04:14 PM
Vampiro's Avatar
Vampiro
cheap mods
does anyone know of cheap power mods for the 300 6? im a high schooler with a very limited budged and i can't go without this truck for more than a day or 2. im looking for something bolt on, that'll increase the power. a 2 barrel carb im thinking of if i can find the adaptor. i have an open air breather, new plugs, wires, coil, rotar, dist. anything else that can increase power?
Old May 16, 2002 | 11:29 PM
spshultz's Avatar
spshultz
cheap mods
I don't believe there is anything that will net you a large increase without getting just a bit spendy.
I did an MSD coil and upped the plug gap on my '85. Helped smooth it out. Also went with Brass cap and rotor. Going to do MSD-6A soon. Also rebuilt my 1bbl carb and put 3" hi-flow cat, Flowmaster Delta-Flow 40 series muffler and 2.5" exhaust on. This brought it back to stock power (was in need of a major tuneup when I bought it) and it sounds damn good.
But to see something noticeable you will need 2bbl or 4bbl carb, intake, headers and probably a cam.
Old May 17, 2002 | 01:22 AM
tetraruby's Avatar
tetraruby
cheap mods
I'm doing the MSD swap next week, will let you know how it goes - here or in '73-'70 forum. I posted a message a while ago (turned into a pissing match) about disengaging the EGR. There's a distinct difference when the WOT valve opens, effectively closing the EGR, in power because of increased displacement. If you have an EGR valve installed and want to try it out, simply plug the EGR vacuum line with a golf tee(temporary) and try it out. I'm sure you have a similar setup as to my '79 F100 - incedently same color too.
