1978 - 1996 Big Bronco
motor ?
Old Nov 14, 2007 | 02:34 PM
blueovalfan's Avatar
blueovalfan
motor ?
I bought a 79 bronco with a bad motor in it , I found one in a Lincoln car. Will it swap into my bronco with a oil pan swap? The motor is a 400
Old Nov 14, 2007 | 02:43 PM
Conanski's Avatar
Conanski
Which vehicle/s have the 400? If both are you're laughing.. should bolt right in.. with an oilpan/pickup swap. If the Bronco has a Windsor in it and your donor is a 400(or vese versa) then the bell housings won't match.
Old Nov 14, 2007 | 02:48 PM
blueovalfan
both have 400s
Old Nov 14, 2007 | 04:36 PM
BroncoRoadKill's Avatar
BroncoRoadKill
same motor just use your oil pickup and pan.
