motor ID...
Old Nov 14, 2007 | 02:18 PM
rockher_man's Avatar
rockher_man
Lightbulb motor ID...
Just picked up a '56 F100 running a 1972 302 & C$. Runs good for now...but during the "rebirth" of our new Effie...we also have a 1980-something 302 sitting on a stand in the garage that was running when yanked out of a mid-to-late 80's Mustang.
Please help me ID the carburated 302 that has been sitting in the garage for a few years...where are the block #'s...it's a long story...
-THANX...
Old Nov 14, 2007 | 02:46 PM
Conanski's Avatar
Conanski
Block casting numbers are near the oilpan at the rear on 1 side or the other.
Old Nov 14, 2007 | 06:42 PM
tjc transport's Avatar
tjc transport
i ain't rite
look for the block casting numbers on the passenger side, behind the starter.
Old Nov 15, 2007 | 06:12 AM
baddad457's Avatar
baddad457
Flat tappet blocks have the casting number on the passenger side above the starter, 5.0 roller blocks have it on the drivers side in the rear corner.
Old Jan 10, 2008 | 04:14 PM
rockher_man
Question Motor ID...
...Ok...found some numbers cast above the starter area on the passenger side of the block:
EOAE
D3C
DOESN'T MEAN SQUAT TO ME!!
On the rear top-side of the intake along one of the runners there is a number cast in to it, (intake might be aluminum?): RF-E3ZE-9425-FC
There is a Holley 4-BBL bolted to the intake also...
Double roller timing chain and 2-bolt mains...As far as I know...this motor is STOCK...PLEASE HELP!!!...what is it?????
Old Jan 10, 2008 | 06:30 PM
HemiEater's Avatar
HemiEater
looks like a 80 casting and if I read it right it's a 83.. 50oz balance where as the 72 is 28oz...make sure you get the right flywheel and balancer if you use it.
Old Jan 10, 2008 | 08:44 PM
Beanscoot's Avatar
Beanscoot
Yes it sounds like a 1983 HO Mustang/Capri motor. This uses the 351W marine (flat tappet) cam which means it has the 351W firing order as well.
Old Jan 10, 2008 | 09:19 PM
baddad457's Avatar
baddad457
It's an 83 Stang motor, but at this point in time, nothing to write home about. The blocks aren't particularly desireable and the early 50 oz cranks are known to break in half. Not a roller motor either. The intake brings about $50 on ebay. Heads aren't desireable either. Hope you didn't pay too much for it. It's really only good as a core for rebuilding, reusing the block, & rods. Plus any front end accessories that came with it.
Old Jan 11, 2008 | 07:48 AM
rockher_man
Talking 302 Id...
THANKS...at least I know what it is!!! Didn't get a chance to look at the left side of the block...too much "stuff" in the way...
Old Jan 11, 2008 | 12:41 PM
baddad457's Avatar
baddad457
I was off anyway on the roller block's casting number location. It is on the passenger side like the rest. Been looking at too many on my engine stand, flipped upside-down.
jimbo beam
May 21, 2016 08:51 AM
patrickj20
Nov 26, 2015 09:34 AM
belchfire
Nov 2, 2013 01:40 PM
thumbs08
Mar 29, 2012 02:06 PM
scott9320
Jan 11, 2007 12:49 PM
