Need Higher Compression
Old May 16, 2002 | 03:35 PM
gdavis2265's Avatar
gdavis2265
What compression ratio can I expect?
Using a stock 240 head and stock '76 300 block and pistons (8.5:1 approx)
How much would this head up the compression- Maybe 1 point?
How much if I milled .060" of the stock 300 head?
Help, need more HP
Old May 17, 2002 | 11:50 AM
Pentekno2's Avatar
Pentekno2
Old May 17, 2002 | 01:30 PM
chickenmanq's Avatar
chickenmanq
What about using a thinner head gasket? You wouldn't need much to bump it a point or two.
Old May 17, 2002 | 01:43 PM
mantta's Avatar
mantta
You need to have the ratio for the 240, ok, the cubic inch difference between the 240 and the 300 is 60 cubic inches divided by six = 10 cubic inches per cylinder. If the 240 had an 8.0 to 1 ratio that means that instead of comrpessing 40 cubic inches you are now compressing 50 cubic inches into that same volume head. Your combustion chamber volume in this senerio is 5 cubic inches. So, add 10 cubic inches to that and that would mean that you are compressing 50 cubic inches into a 5 cubic inch combustion chamber you will have a ratio of 10.0 to 1.
