Troubleshooting P0125 - ECT Sensor defective
Old Nov 14, 2007 | 01:02 PM
EricExplorer's Avatar
EricExplorer
Thumbs up Troubleshooting P0125 - ECT Sensor defective
Hello All,
Hope I can get a little bit of help and a lot of advise from the forum. I have a '96 Explorer XLT 4WD, 4.0 L V-6, that was diagnosed with the P0125 error code from the ODBII PCM. I bought the replacement thermostat, but am not sure which device is the ECT sensor? In looking at the assembly there is a Coolant Temperature Sending Unit, looks like a switch only, and there is a EEC-iV coolant temperature sending unit, that appears to the the thermistor or similar device. Which one in this case, if not both , would generate the P0125 error?
I'm thinking about just replacing the thermostat, and taking a chance, but since I've got it apart, should I go ahead and replace the ECTsensor(s)?
THanks for your help and thanks for the Explorer Truck Forum.
Old Nov 14, 2007 | 03:18 PM
87 XLT's Avatar
87 XLT
If the temp gauge is reading colder then it normally does, just replace the T-stat & the PO125 "insuficent coolant temp to enter closed loop" should go away.
Old Nov 14, 2007 | 03:23 PM
EricExplorer
Thanks 87 XLT, that is exactly what it is doing. I'll give it a try. Just in passing, would you use a gasket paste on the housing and engine before reinstalling?
Thanks again.
Old Nov 14, 2007 | 03:45 PM
87 XLT's Avatar
87 XLT
Your Haynes or Chiltons manual will probably tell you to use a new gasket & a thin layer of RTV on both sides of the gasket.
Thats what I would do.
Be careful not to overtighten the T-stat housing so as not to break it.
Been there & done that one myself.
Old Nov 14, 2007 | 04:06 PM
danr1's Avatar
danr1
The new stat should include a new rubber seal that goes on around the edge of the stat itself, no sealant needed.
Old Nov 14, 2007 | 04:15 PM
87 XLT's Avatar
87 XLT
Good info, it's been awhile since I changed a stat. Was wondering if Ford still used the rubber ring. Now I know.
Old Nov 14, 2007 | 06:30 PM
danr1's Avatar
danr1
Yea I really like that setup, makes for a quick easy clean job of swapping the stat out.
Old Nov 14, 2007 | 07:25 PM
aquanaut20's Avatar
aquanaut20
Check both seating surfaces of the T-stat housing/block, if corroded/pitted, clean well and suppliment the O ring with RTV.
Old Nov 19, 2007 | 08:44 AM
EricExplorer
Just a quick update for you guys. Replaced the T-Stat and engine temp went right up to normal. It looks as though the gas milage has improved as well, but most of all is that there is heat again to defrost the windshield on these cold mornings. Thanks 87 XLT and all the rest for your help. I'm sure that I will be back again needing help.
Old Nov 19, 2007 | 09:21 AM
aquanaut20's Avatar
aquanaut20
Glad that worked for you and, thanks for following up with the SITREP...P
Old Nov 19, 2007 | 12:16 PM
87 XLT's Avatar
87 XLT
Yeah, staying warm, being able to see where you are going & not running rich all the time are very good things.
Congrats on the fix & thanks for the update.
Question
1997 - 2003 F150
15
Sep 17, 2025 03:41 AM
Super crew hunter
1997 - 2003 F150
Apr 11, 2013 06:41 AM
wazez
1997 - 2003 F150
Apr 20, 2011 09:49 AM
john19999
Nov 21, 2010 08:26 AM
tsm2a
1983 - 2012 Ranger & B-Series
23
Nov 18, 2007 03:00 PM
