MAP Sensor testing.
Old Nov 14, 2007 | 02:30 AM
blu beast's Avatar
blu beast
MAP Sensor testing.
Does any one know what the voltage or frequency should be for the return signal for the MAP sensor. I have my 5v reference, and my map sensor frequecy from the middle pin, but I have almost no voltage on the last pin(signal return). Any ideas would be helpful and greatly appreciated.
Old Nov 14, 2007 | 04:43 AM
EPNCSU2006's Avatar
EPNCSU2006
Signal return is nothing more than the computer's own ground circuit. There should be little to no voltage between this wire and ground. The signal return line should be your zero volt reference point when testing sensors instead of using battery ground.
Old Nov 14, 2007 | 06:26 AM
frederic's Avatar
frederic
80-160hz.
http://fordfuelinjection.com/?p=27
Old Nov 14, 2007 | 06:33 AM
subford's Avatar
subford
On Ford applications, a multimeter that can read
frequency is normally required to check the sensor’s
output. But you can also use an ordinary tachometer
because a tach can display a frequency signal.
Here’s the procedure:
1 Set the tachometer to the four-cylinder scale
(regardless of how many cylinders the engine has).
2 Connect one tachometer lead to the middle terminal
on the MAP sensor and the other tachometer test
lead to ground.
Connect the two jumper cables the same as before,
attaching each end terminal on the sensor to its
respective wire in the wiring connector.
4 If you want to measure engine vacuum so you can
correlate it to a specific frequency reading, connect
a vacuum gauge to a source of manifold vacuum
on the engine, or tee the gauge into the MAP
sensor hose.
5 Turn the ignition ON and note the initial reading.
The reading on the tachometer should be about
454 to 464 at sea level, which corresponds to a
frequency output of 152 to 155 Hz.
6 Start the engine and check the reading again.
If the MAP sensor is functioning properly, the
reading should drop to about 290 to 330 on the
tachometer, which corresponds to a frequency
output of about 93 to 98 Hz. No change would
indicate a defective sensor or leaky or plugged
vacuum hose.
Old Nov 14, 2007 | 05:22 PM
EPNCSU2006's Avatar
EPNCSU2006
He's got the frequency on the middle pin (sensor output) already...
The signal return is not supposed to have any voltage or frequency by itself, since it is the sensor ground or zero volt circuit.
Old Nov 14, 2007 | 06:04 PM
subford's Avatar
subford
Yes I know what he said but I posted mostly for someone else that does a search on the subject.
Old Nov 14, 2007 | 06:24 PM
EPNCSU2006's Avatar
EPNCSU2006
Good idea....I didn't think of that.
Mountain54
Mar 7, 2017 04:38 PM
Matt.gullo
Aug 19, 2016 08:39 PM
rickdavis81
May 12, 2016 04:34 PM
fenix1
Electrical Systems/Wiring
Jun 8, 2013 09:31 PM
pjnadon
Jan 22, 2011 10:01 PM
