17 thousand $$$ 7.3
Old Nov 13, 2007 | 10:38 PM
bigtorque's Avatar
bigtorque
17 thousand $$$ 7.3
so, im at the local diesel shop and one of the mech. says check this out.
so he shows me a bill, with list of broken pieces to include purchasing a new long block and all the fixins, so heres the story i got. 7.3 powerstroke in a pump truck with a 30K pump system in the bed, so ended up being water in the fuel, fuel filter and fuel lines, owner adds a heat type additive for diesel fuel, it dissapates the water but the fuel water seperator doesnt catch the water now, and flows through the fuel filter and forms back into water droplets, is pushed through the rail into the injector, superheated at the injector tip, and explodes blowing the injector tip off, and through the piston, which intales breaks the rod and scars the crank, ruining the injector, while the motor turned a few times before it was shut down, a fragment of the piston head bends a valve and goes out the exhaust into the turbo, at which time it tears up all the blades, IN ALASKA THATS A 17K PARTS AND LABOR MISTAKE, new rebuilt long block found local for 11K.
Old Nov 13, 2007 | 11:25 PM
greedy737's Avatar
greedy737
I'm lost, How did he get water in the fuel!!
Old Nov 13, 2007 | 11:31 PM
santacruzf250's Avatar
santacruzf250
Long blocks can be shipped from the mainland for under 5K.
Old Nov 14, 2007 | 12:12 AM
CSIPSD's Avatar
CSIPSD
Dude got RIPPED OFF...
Old Nov 14, 2007 | 08:15 AM
7.3L DID TD's Avatar
7.3L DID TD
Do you think? look here...
http://www.powerstrokedieselengines.com/
http://www.usdieselengines.com/7.3l_...oke_engine.htm
http://www.65ldiesel.com/page/page/986244.htm
http://www.rhinoengines.com/motorcraftdieselengines.htm
It took about 3 minutes to save you over half your bill.
Old Nov 14, 2007 | 09:45 AM
blksiryder's Avatar
blksiryder
that is love for the truck you have for 17k i would of 1-got a new truck 2-got a good used truck. but hey thats just me.
Old Nov 14, 2007 | 03:19 PM
santacruzf250
my whole '02 7.3L wasn't 17k
Old Nov 14, 2007 | 07:13 PM
CSIPSD's Avatar
CSIPSD
I am putting a mild built motor in mine for under 8k...
Old Nov 14, 2007 | 08:18 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I am assuming the use of fuel treatment such as HEET causes the water seperator to become ineffective.
Old Nov 14, 2007 | 08:44 PM
bigtorque's Avatar
bigtorque
thats my assumption of HEET and the fuel water seperator, and unfortunatly, shipping anything up here with any kind of size or weight normaly cost as much as the item being shipped.
Old Nov 14, 2007 | 09:20 PM
John7894's Avatar
John7894
I was thinking the same thing. I paid 12K for my entire truck...
