5.8 roller?
Old Nov 13, 2007 | 10:08 PM
Brett1989's Avatar
Brett1989
5.8 roller?
When did ford switch to the roller cam setup for the 5.8? I was told it was 95 or 96, but I checked a table that has the stock power ratings and it jumped up in 93 and stayed the same until they were discontinued.
Brett
Old Nov 14, 2007 | 12:12 AM
Blurry94's Avatar
Blurry94
Look into the 96-97+ F250's, they switched to a roller cam and mass air around that time frame (before the body style change).
Old Nov 14, 2007 | 12:28 AM
Beanscoot's Avatar
Beanscoot
The roller setup started in 94, or even late 93 in some but not all applications. All 94-up engines are "roller compatible", that is even if they have a flat tappet cam, the block is designed to accept stock roller lifters and cam.
The sure way to determine if a block is roller compatible is to find the "F4TE" casting number prefix on the cylinder block. It is above the starter motor, visible from below the block (the starter may need to be removed to see it though).
Old Nov 14, 2007 | 01:17 AM
Blurry94's Avatar
Blurry94
Yes, but the 5.8's didn't get a roller cam with the F4TE block until 96/97. Those (5.8) blocks will accept roller lifters, spider and dog bones from any factory rollerized 5.0 of that era. Just need to change the pushrods and the distributor gear to a steel piece.
Old Nov 14, 2007 | 05:30 AM
baddad457's Avatar
baddad457
The switch to mass-air didn't occur with the switch to the roller cam. I've seen F4TE roller cammed 5.0's (same cam used with the roller 351) that still had Speed Density EFI. Easiest way to ID a roller is pull a pushrod and measure it. roller 5.0 rods are 6.25" (give or take a few thousandths) 351's would be 7.55"
Old Nov 14, 2007 | 09:37 PM
Brett1989's Avatar
Brett1989
Okay, thanks, I'll see what I can find.
Brett
Old Nov 15, 2007 | 08:32 AM
Conanski's Avatar
Conanski
The info I have is that '94+ trucks got the F4TE roller cam. Like everything else I bet there are exceptions, but as an example my fathers '95 E250 van has a roller 5.8 in it.
Old Nov 15, 2007 | 01:40 PM
Kemicalburns's Avatar
Kemicalburns
the 95 5.8 i have in the rolled 88 bronco has roller cam.
Old Nov 15, 2007 | 09:11 PM
Brett1989's Avatar
Brett1989
How much would it cost to change a 351w from hydrualic to roller? and would it be worth it? I'm looking to get real good power for racing and pulling against people that think chevys or dodges are the best, yet get no worse than 12mpg if possible.
Brett
Old Nov 16, 2007 | 04:37 AM
baddad457's Avatar
baddad457
Unless you have a roller block, forget converting. It's too expensive for the gain you'll see. At a minimum, it'll run you $600 to go roller in a flat tappet block.
Old Nov 16, 2007 | 08:34 AM
Kemicalburns
i forgot to mention the 95 5.8 i had pulled was from an f250.
Old Nov 16, 2007 | 09:52 AM
BADBLUEOVAL351's Avatar
BADBLUEOVAL351
I bought a wrecked 94 E-250 with a roller 5.8 dog bones, spiders and all!
Old Nov 16, 2007 | 07:29 PM
Brett1989's Avatar
Brett1989
Does it make a difference whether it is f-1,2or350? What would I have to do to it to make atleast 300hp and 325tq, preferably more but my budget isn't all that big($1000 is the most I've got, maybe not even that much, it depends on how much the truck costs.)
Brett
Old Nov 16, 2007 | 08:15 PM
baddad457's Avatar
baddad457
Doesn't matter about which truck it was, they all got the same engines.
Old Nov 17, 2007 | 10:41 AM
Conanski's Avatar
Conanski
A 351 will make more TQ than that with any decent aftermarket cam(even 1.7 rockers on the F4TE cam) and longtube headers.. especially if it's EFI. To get over 300HP you'll need ported or aftermarket heads, and a higher flowing intake than the stock EFI unit.
