C6 or C4 ????
Old Nov 13, 2007 | 09:11 PM
dvs's Avatar
dvs
C6 or C4 ????
hey hey i got this 86 150 and the guy i bought it from said he thought it had a c6 in it, i know its not the stock trans b/c it had an overdrive probably the aod, does anybody know where i can find pictures of the tranny pan, b/c i know what mine looks like i need to compair and see for sure before i go and get a shift kit, i dont wanna guess and end up with the wrong kit ?
Old Nov 13, 2007 | 09:16 PM
Franklin2's Avatar
Franklin2
Look at the bottom right of the page in this link.
http://www.lmctruck.com/icatalog/fd/0009.asp
Old Nov 13, 2007 | 09:24 PM
dvs's Avatar
dvs
hey man that took a the weight off of my chest, knowing now that its a c6 and not the 4, now i can get the right kit, thanks alot
Old Nov 14, 2007 | 05:36 AM
tommythomasson's Avatar
tommythomasson
I know you got it already, but for anyone else interested, you can also get it from the ID tag on the driverside door frame (if it's still there).
Trans codes:
A - Four speed manual
B - Four speed manual overdrive
C - Three speed manual
F - Four speed manual
G, K, or Z - Three speed auto (C-6)
J - Three speed auto (C-4)
W - Three speed auto (C-5)
Old Nov 14, 2007 | 01:56 PM
Big_kid's Avatar
Big_kid
My 85 150 shows a trans code "T" with "H9" for an axle. I wonder what that is?
Old Nov 14, 2007 | 02:18 PM
tommythomasson
Originally Posted by bd4martin
All straight out of the Ford Red Book
SERIAL NUMBERS
DESCRIPTION
1FTHF15FXCLA00001
IFT-Ford Motor Co. Truck Complete, 1FD-Ford Motor
Co. Truck incomplete, 1FC- Ford Motor Co. Truck Stripped
Chassis,
H-Hydraulic Brakes Class: A-Class A not greater than 3,000 lbs.,
B-class B 3,000-4,000 lbs., C-class C-4,001-5,000 lbs.,D-
class D 5,001-6,000 lbs., E-class E 6,001-7,000 lbs., F-class
F-7,001-8,000 lbs., G-class G 8,001-9,000 lbs.,
H-class G 8,501-9,000 lbs., J-class H 9,001-10,000 lbs.,
K-class 3 10,001-14,000 lbs.
F15-Model Series: F10-F100, F14-F150 4x4,F15-F150, F25-F250,
F26-F250 4x4, F27-F250 Chassis-cab, F28-F250 Chassis-cab 4x4,
F35-F350, F36-F350 4x4, F37-F350 Chassis-cab, F38-F350
Chassis-cab 4x4, U15-Bronco, X14-F150 SuperCab 4x4, X15-
F150 SuperCab, X25-F250 SuperCab, X26-F250 SuperCab 4x4
X35-F350 SuperCab
F-Engine code-4.2L V-8, E-4.9L I-6, F-5.0L V-8, G-5.8L V-8
Z-6.6L V-8, O-DSO, 9-4.9L I-6 LPG Conversion
X-Check digit, which varies
C-Model year, C-1982
L-Assembly Plant, see appendix
A00001-Numerical sequence of assembly
CERTIFICATION LABEL DSO CODE - See appendix
LOCATION
Serial number located on driver's side of dash, visible through the window and on Certification Label which is attached on
rear face of driver's door.
BODY CODES-The first two digits indicate trim color
and seat/material type code(see below) and the third digit
indicates back of cab Body Type:
3 Flairside Pickup
4 Styleside Pickup
8 Chassis-cab
M SuperCab Pickup
P SuperCab Chassis-cab
MODEL & GVW CODES
F-100 4,650
F-101 4,650
F-102 4,900
F-103 5,050
F-140 4x4 5,500
F-141 4x4 5,700
F-142 4x4 6,050
F-143 4x4 6,250
F-150 5,250
F-151 5,450
F-152 4x4 5,800
F-153 4x4 6,100
F-250 6,300
F-251 6,900
F-252 7,800
F-257 8,700
F-260 4x4 6,800
F-261 4x4 7,400
F-263 4x4 8,700
F-278 7,900
F-279 9,200
F-350 8,900
F-351 9,100
F-352 10,000
F-361 4x4 9,100
X-140 4x4 6,450
X-150 5,450
X-151 5,650
X-152 6,050
X-153 6,250
X-250 6,500
X-251 6,700
X-252 7,100
X-253 7,300
X-254 7,700
X-255 8,000
X-259 8,900
X-260 4x4 7,100
X-261 4x4 8,200
U-150 5,400(Bronco)
U-151 5,500(Bronco)
U-153 6,050(Bronco)
U-154 6,300(Bronco)
ENGINE CODES
F-SERIES
D - 255 c.i. V-8 2bbl
E - 300 c.i. I-6 1bbl 117hp
F - 302 c.i. V-8 2bbl 154hp
G - 351 c.i. V-8 2bbl 161-165hp
Z - 400 c.i. V-8 2bbl 167-177hp
TRANSMISSION CODES
F-SERIES
Four speed manual A
Four speed manual overdrive B
Three speed manual C
Four speed manual F
Three speed automatic (C-6) G
Three speed automatic (C-4) J
Three speed automatic (C-6) K
Three speed automatic (C-5) W
Three speed automatic (C-6) Z
REAR AXLE CODES
F-SERIES & BRONCO
2.47:1 H7,07
2.75:1 01,H3
3.00:1 C2,H4,02
3.25:1 H5,04,
3.33:1 B5,
3.50:1 H6,
3.54:1 B7,C7,D1
3.73:1 C6,D6
4.10:1 C1,D3,D7,
EXTERIOR COLOR CODES
F-SERIES/BRONCO
Black 1C
Silver Metallic 1G
Candyapple Red 2K
Maroon 2L
Light Blue 32
Medium Blue 34
Light Medium Blue 3F
Dark Blue Metallic 3L
Medium Blue Metallic 3P
Med. Dark Spruce Met. 4J
Medium Fawn Metallic 5A
Dark Caramel Metallic 5G
Light Fawn Metallic 5H
Light Fawn Metallic 5K
Dark Brown Metallic 5Q
Light Tan 6U
Pastel French Vanilla 6Z
Medium Spruce 74
Light Spruce Metallic 7B
Dark Pine Metallic 7M
Medium Fawn Metallic 82
Fawn 89
Dark Chamois Metallic 8A
Medium Bittersweet Met.
Medium Bittersweet Met. 8G
White 9A
INTERIOR TRIM CODES-F-SERIES
Black AA,CA,DA,GA,HA
Blue AB,CB,DB,GB,HB,NB
Red AD,CD,DD,GD,HD,ND
Spruce AR,CR,DR,GR,HR
Nutmeg AT,CT,DT,GT,HT,NT,
Fawn AU,CU,DU,GU,HU
BRONCO
Black AA,BA,DA,FA,GA
Blue AB,BB,DB,FB,GB
Red AD,BD,DD,FD,GD
Spruce AR,BR,DR,FR,GR
Nutmeg AT,BT,DT,FT,FT
Fawn AU,BU,DU,FU,FU
I don't see your #'s in there... numberdummy would probably be a good one to ask...
Old Nov 14, 2007 | 02:59 PM
Big_kid's Avatar
Big_kid
Thanks for your help!
choppermanjapan
Nov 25, 2012 07:50 PM
F250DUDE66
May 19, 2009 01:09 PM
displacement4me
British Columbia
Mar 8, 2009 02:58 PM
Justforfishing
Jan 26, 2006 02:38 PM
highwaytolife
Arizona Chapter
13
Nov 23, 2004 06:42 PM
