Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Adding HP on 2nd Gen
Old Nov 15, 2007 | 08:59 AM
MisterCMK's Avatar
MisterCMK
Originally Posted by wd13
What kind of add ons do they have for protection when the pump quits on you and you're way over timed and under WOT?
It all sounds great in theory but for me, I'll stick to running timing/boost that I have octane to cover.
Bingo. That is what I would be afraid of, trashing the motor if the meth quits working
Old Nov 16, 2007 | 12:34 AM
commandersander's Avatar
commandersander
Awesome!!!
"Bingo" showed up to the party!!!!
Boost bypass solenoid.....I made mention of it in the previous post. Yes, there is already one there....but it does not govern anything you add like meth injection.
The add-on allows for the float switch to "tell" the secondary solenoid to activate the bypass solenoid on the truck.
He already has a custom SCT Dyno tune (accept NO substitute!!!) so changing the timing can be done in-cab. Also, the controller has a perimeter range of 0-5v.....so he/she/you/anyone can set the system to activate at WOT, idle....or anywhere in the middle.
Believe me....I'm not on the payroll for Snow....in fact.....my system is basically the same before they came to market with it......guess it could have been my "hula-hoop!"....
Anyway....it is a safe.....AND I DO MEAN SAFE....way to add HP for CHEAP.
As far as the "mix".....
50/50 water methanol for a buck.....store brand wherever you shop for washer fluid.....just make sure it is the "winter mix"....
Methanol won't freeze....therefore.....ammonia is replaced by methanol at a 1:1 ratio to water....just enough to keep your plastic resivoir from splitin during those cold months.....
Old Nov 17, 2007 | 11:01 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by ss150
My brother has an '03 Lightning that is currently at 400 rwhp. He is looking to take it to 450 rwhp, where he will hold off and start saving fr a new rotating assembly. His mods right now consist of a 6# lower, C&L air intake, C&L 95mm MAF, Accufab TB, C&L upper plenum, Accel coils, NGK TR6's, and a custom SCT dyno tune. What do you guys recommend he do to get the extra 50 rwhp?
He's about tapped without nitrous, heads/cams, or different blower.Or He could always install every bolt-on know to man, spend a ton of cash and get close to that.
Yep, +1.
You can add the ported blower, but even with a port matched upper plenum and throttle body, like wd stated, you'll get a little closer, but not another 50hp.
Plus, with ported blowers, you have to be careful on the L's. They are hit or miss when it come to producing power. Some have had a nice HP increase while suffering zero torque loss, but quite a few L owners have experienced max torque loss when a ported blower has been added.
Yes, the power under the curve looks nicer on a dyno graph, but for some, the gain of HP/loss of torque pretty much canceled out the pro's of getting the s/c ported.
Stewart
Old Nov 17, 2007 | 11:02 PM
Stewart_H's Avatar
Stewart_H
Is there any power to be had in upgrading the cooling system, like electric fans and heat exchanger?
Minor amounts.
These mods fall under the "every bolt-on known to man" that wd covered in his above post.
However, I would make one notable change. Don't go with the Cobra R water pump. Go with the Navigator pump.
The R pumps actually flow less than your OEM pump (IIRC), which is not good, plus, the Navi pump does the same job as the R, but it flows more!
Stewart
Old Nov 17, 2007 | 11:11 PM
Stewart_H's Avatar
Stewart_H
LOL!
Well, yes and no.
It all depends on who you have tuning your truck, and what software they use.
For example, I'm not sure what Troyer performance uses, but Troyer is one heckuva tuner, and if he uses a different tuner than SCT, does that diminish his tuning abilities?
Nahhh, not at all.
Sniper Tuning software is starting to make a nice, positive splash in the tuning world too.
Like I said, it all depends on who you use to tune your truck.
Personally, I use the SCT handheld with tunes provided by JJ at Woodbine Motorsports. I used to use Sal at Powersurge Performance, and he tuned my truck with a Predator.
Stewart
Old Nov 18, 2007 | 01:41 AM
2002BLGT's Avatar
2002BLGT
Originally Posted by Stewart_H
LOL!
Well, yes and no.
Nahhh, not at all.
Stewart
Troyer is close to me , he uses SCT , I use Sniper myself and love it .....
Darkknight6.0
Mar 11, 2017 07:59 PM
weber6point2
6.2L V8
Jan 26, 2014 06:18 PM
jaytee04
Dec 4, 2012 11:27 AM
jaytee04
2009 - 2014 F150
18
Sep 3, 2012 06:35 AM
