4" cat
Old Nov 13, 2007 | 10:01 AM
ModMMax's Avatar
ModMMax
4" cat
Based on the advice of friends, I decided to improve an already great truck (05 F350 4WD SB Crew) by changing the exhaust system to a 4" turbo back. My current home province (Sask) does not emmisions test but I am moving to Ontario in the spring and will have to have the truck inspected, including smog testing. So, I began looking for a 4" cat and did find a company making them. During a phone call to them they said their 4" high flow diesel cat was designed and built for a F7.3. So, here's the question. Are the flow volumes and other exhaust characteristics of the 6.0 similar to the 7.3? Should I be concerned about installing this cat on my system? Comments and opinions appreciated. Thanks in advance.
Old Nov 13, 2007 | 10:49 AM
blackhat620's Avatar
blackhat620
Don't waste your money on the A/M Cat. The OEM Cat has very little restriction and you will see virtually no improvement by installing the A/M Cat. Just install the 4" turbo back ehaust (BTW the DP is 3.5") and you are good to go.
Old Nov 13, 2007 | 12:27 PM
ModMMax's Avatar
ModMMax
My 4" A/M exhaust system is turbo back and as such does not include a cat. I garbaged the stock exhaust system including the stock cat. I am looking to install a 4" cat to ensure the truck will pass emmisions testing. Is an aftermarket 4" cat designed for a ford 7.3, compatible with the 6.0 engine?
Old Nov 13, 2007 | 12:41 PM
blackhat620
I do not know, you will have to asked the manufactures of the A/M Cat. Why did you throw away the factory Cat?
Old Nov 13, 2007 | 06:56 PM
WWBeast's Avatar
WWBeast
hey do you think there is much difference between a straight piped 4 inch vs no cat 4inch turbo back MBRP system as far as loudness goes?
Old Nov 13, 2007 | 08:44 PM
ModMMax's Avatar
ModMMax
I don't know about a straight piped 4". My only experience is changing a stock system to a turbo back 4" system with the straight through muffler that came with the kit. I like the increased exhaust noise and I like the turbo sound at low rpm's. Its not annoying but it does turn heads a little in traffic and its a lot more fun to drive, especially from 20-50 mph. BTW, I changed the intake to a stage 2 AFE as well. I've noticed a small increase in fuel mileage when towing, maybe 1-2 mpg. Its hard to judge if there is more power but I'm guessing there is little or no increase.
champ7718
2004 - 2008 F150
Jul 17, 2007 10:24 AM
ceetwarrior
28
Jul 26, 2005 08:47 AM
coplin
Exhaust Systems
Jun 14, 2005 03:27 AM
94steve
Exhaust Systems
Apr 28, 2005 10:20 PM
Johns331
Jul 4, 2001 04:04 AM
